FlyB0y Posted March 1, 2006 Author Share Posted March 1, 2006 Well, I can't seem to be able to edit the title, so I will say it here ... one problem I have had to fix recently was the dammage the hose made to the paint on the hood. At speed, the slight flexing of the hose rubbing at 2 places on the hood wore through the paint:rolleyes: so now I have some of those 3" ferncos covering those 2 spots. Link to comment Share on other sites More sharing options...
WAWalker Posted March 1, 2006 Share Posted March 1, 2006 Thx! I suggest making a in-line filter like I have in the 3" line. It's really easy ... all you need are a 4" fernco (rubber boot with 2 hose clamps for joining to pieces of 4" pipe) 2 4" sink strainers that are made of fine mesh like that of a screen door, 2 4" x 3" reducing bushings and a 4" round disk of filter foam, I made mine from the foam filter of my Edlebrock filter (can be bought for $20 at a parts store and will make 5 - 6 of these filters) this set-up is completely waterproof too, though I don't know that I wana re-pack the grease in my bearings and make vents for my diff & tranny, mostly I made this to cut down on dust being ingested and I originally planned on putting in on of those "turbonators" in-line :cool: ... not sure I will yet So is that all you have for an air filter? I take it that the filter foam you are talking about is the foam ring made to go around an actual air filter? So your one an only barier to keep dirt out of your engine is a thin 4" round peice of pre-filter foam? Link to comment Share on other sites More sharing options...
subestyle18 Posted March 1, 2006 Share Posted March 1, 2006 Looks kinda like my set up toilet adapter and 2nd bat and all. http://www.ultimatesubaru.org/photos/showphoto.php?photo=8369&cat=500&ppuser=1525 Link to comment Share on other sites More sharing options...
FlyB0y Posted March 1, 2006 Author Share Posted March 1, 2006 So is that all you have for an air filter? I take it that the filter foam you are talking about is the foam ring made to go around an actual air filter? So your one an only barier to keep dirt out of your engine is a thin 4" round peice of pre-filter foam? Well, it's foam from a Edlebrock Filter, not just a prefilter ... also the screen material of the drain strainers will keep back some of the big stuff ... one other modification I am doing is a 4" pipe ring to act as a spacer so the filter foam isn't squished so much, might be keeping it from breathing as freely as it should. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 1, 2006 Author Share Posted March 1, 2006 Looks kinda like my set up toilet adapter and 2nd bat and all. Yeah! looks like we had similar brain-storms ... what kind of flexible line did you use? RV sewer line like mine? Link to comment Share on other sites More sharing options...
WAWalker Posted March 1, 2006 Share Posted March 1, 2006 Cool, if it is from an actual urethane foam air filter element it should filter just fine. Restriction as you say may be an issue, you'll probably just have to clean it more offten due to the small surface area. Link to comment Share on other sites More sharing options...
Phizinza Posted March 2, 2006 Share Posted March 2, 2006 foam filters are the best kind as far as I know. With regular cleaning and oiling they will be just as good of a filter as a paper one and let a lot more air thru. (remember the oil!) But of cause, being a snorkle and being so high up, there will be less dust. So that means less cleaning. Interesting that that was your purpose FlyB0y. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 2, 2006 Author Share Posted March 2, 2006 foam filters are the best kind as far as I know. With regular cleaning and oiling they will be just as good of a filter as a paper one and let a lot more air thru. (remember the oil!) But of cause, being a snorkle and being so high up, there will be less dust. So that means less cleaning. Interesting that that was your purpose FlyB0y. Well, I would like to do the whole fording rivers thing, but right now I can't really afford the bearings I just replaced 2x in the last month ... got that problem fixed, but untill I start making better money at my new job, I don't like the idea of trashing bearings early or having to re-pack them with grease every week ... but some day I will be able to afford to play in the water Link to comment Share on other sites More sharing options...
subestyle18 Posted March 2, 2006 Share Posted March 2, 2006 The blue hose is a heavy duty marine air vent hose. Its pretty thick and good for over 200 f. I work at a marine hardware store so it was just laying around. David Link to comment Share on other sites More sharing options...
FlyB0y Posted March 3, 2006 Author Share Posted March 3, 2006 The blue hose is a heavy duty marine air vent hose. Its pretty thick and good for over 200 f. I work at a marine hardware store so it was just laying around.David Cool, I will have to look into some if my hose proves too light-weight ... I am also now working in a K&N cone filter, my filter just has too small surface area. Link to comment Share on other sites More sharing options...
Phizinza Posted March 3, 2006 Share Posted March 3, 2006 I am also now working in a K&N cone filter, my filter just has too small surface area. I thought what you explained seemed a little small. Lets see what you can come up with next. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 3, 2006 Author Share Posted March 3, 2006 Ok, here's the $60 up-grade to a K&N filter easily obtainable at Walmart. This mod only changed the ferncos (rubber boots) and added a piece of 6" PVC for the center ... so it will not require any mods to any other part of the snorkle :cool: Link to comment Share on other sites More sharing options...
Phizinza Posted March 4, 2006 Share Posted March 4, 2006 Looks clean flyboy. nice job. Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 5, 2006 Share Posted March 5, 2006 I'd incorperate the two rubber hoses sticking out of the mounting plate into the snorkel. They used to be sucking filtered air, and now it looks like they aren't Might be time to break out JB weld and some brass nipples! Link to comment Share on other sites More sharing options...
FlyB0y Posted March 5, 2006 Author Share Posted March 5, 2006 I'd incorperate the two rubber hoses sticking out of the mounting plate into the snorkel. They used to be sucking filtered air, and now it looks like they aren't Might be time to break out JB weld and some brass nipples! Hmmm not a bad idea, but only one is the PCV breather, the other is a blank with a plug in it ... I guess your right, I don't know why but I was thinking that was a exit, not a inlet for the PCV system ... maybe because it has a tendency to spit a little oil now and then Link to comment Share on other sites More sharing options...
FlyB0y Posted March 8, 2006 Author Share Posted March 8, 2006 Well, I was never really happy with the whole "toilet flange" adaptor for the oval shaped top of my weber ... well I finally got the idea to use basicly the same roof flashing I have on the hood for the exit of the snorkle ... this one is the same size, just made of black plastic. Here are pics of the results (also this pic shows the new K&N filtered air box made from 4 x 6" ferncos ... enjoy!) P.S. almost forgot to add the crank breather to the filtered air ... adding pic ... Link to comment Share on other sites More sharing options...
WAWalker Posted March 8, 2006 Share Posted March 8, 2006 Lookin' good. Link to comment Share on other sites More sharing options...
FlyB0y Posted March 9, 2006 Author Share Posted March 9, 2006 Lookin' good.ty, ty :cool: Link to comment Share on other sites More sharing options...
