Wasteland Posted February 26, 2006 Share Posted February 26, 2006 Does anyone know if the Loyale wiring harness is stubed out the same as a GL I'd like to pull the inst panel from a GL to put into my Loyale for the volt and oil gauges but am not sure if it's a plug and play or if I'd have to rewire abunch of crap. Link to comment Share on other sites More sharing options...
pheonix165 Posted February 26, 2006 Share Posted February 26, 2006 depends on what year i think, but don't quote me on that. gl is a pre-90s vehicle so i don't think it would work in a post 90s loyal. but like i said don't quote me Link to comment Share on other sites More sharing options...
EYE_WHY Posted February 27, 2006 Share Posted February 27, 2006 but like i said don't quote me Sorry, couldn't resist. :D:D:D:D I don't think the year matters, I'm pretty sure that if GL wiring harness fits a 91 Loyale, it would fit any year Loyale. The key is finding out if GL harness fits Loyale harness, I can't imagine why it wouldn't. They tried to keep most electrical/wiring/connector things the same when changing from GL/DL to Loyale. Link to comment Share on other sites More sharing options...
Numbchux Posted February 27, 2006 Share Posted February 27, 2006 as long as the drivetrain setup matches, it'll work. an AT single range 4WD GL gauge cluster will fit in an AT single range loyale. a FWD GL cluster will fit a FWD loyale. I'm not sure about the dual ranges, as they have a 'lo' indicator. so someone else would have to chime in for that, but if you happen to have one that matches, you'll be fine. Link to comment Share on other sites More sharing options...
Wasteland Posted February 27, 2006 Author Share Posted February 27, 2006 as long as the drivetrain setup matches, it'll work. an AT single range 4WD GL gauge cluster will fit in an AT single range loyale. a FWD GL cluster will fit a FWD loyale. I'm not sure about the dual ranges, as they have a 'lo' indicator. so someone else would have to chime in for that, but if you happen to have one that matches, you'll be fine. Rad Thanks I thought they where the same but it never hurts to ask, gauges here I come! Link to comment Share on other sites More sharing options...
pheonix165 Posted February 27, 2006 Share Posted February 27, 2006 Sorry, couldn't resist. :D:D:D:D I don't think the year matters, I'm pretty sure that if GL wiring harness fits a 91 Loyale, it would fit any year Loyale. The key is finding out if GL harness fits Loyale harness, I can't imagine why it wouldn't. They tried to keep most electrical/wiring/connector things the same when changing from GL/DL to Loyale. i was just thinking that if a post 90's loyal was fuel injected it might use a different type of sending unit for the gages...that's how is for some nissans anyway Link to comment Share on other sites More sharing options...
Numbchux Posted February 27, 2006 Share Posted February 27, 2006 i was just thinking that if a post 90's loyal was fuel injected it might use a different type of sending unit for the gages...that's how is for some nissans anyway most EA82 GL's were fuel injected too and I used a cluster from an '88 SPFI GL in my '85 carbed GL, plug and play it's the fancy digi dashes that use different senders Link to comment Share on other sites More sharing options...
zyewdall Posted February 27, 2006 Share Posted February 27, 2006 Don't know about dashes, but I stuck an engine from a '91 Loyale into a '87 GL. It all matched up, except the GL had a big square plug for the wiring harness where the Loyale had a round one All the wires were the same color, so I cut off the wrong plug and soldered the right one on there, and it worked. Link to comment Share on other sites More sharing options...
