Caboobaroo Posted February 26, 2006 Share Posted February 26, 2006 Its been so nice out the past few days. It sucked cause I had to work until today which is one of my days off. So I decided to quit being lazy and gettin my WRX intercooler installed where its not so jerry rigged in there. LUVMYBRAT was so kind and finding me a filler neck from a gas tank which had the exact reducer I needed on it to go from the 2 7/8" outlet on the intercooler to the 2 3/8" inlet on the throttle body. I cut off the piece I needed and put it on. While I was getting the plumbing fitted and cut, I noticed that I'm going to have to cut my firewall a bit for more clearance for the pipe coming form my TD04 into the back of the intercooler. So thats where I'm at now, then it'll be timing, hooking up some misc vacuum lines and getting her tuned in a little bit better (she seemed like she was only runnin on 2 cylinders, bad timing!). Hopefully this afternoon/evening I can see about taking her around the block under her own power! I haven't done that in this car since I tore into her back in December of 2004. Quote Link to comment Share on other sites More sharing options...
nkx Posted February 27, 2006 Share Posted February 27, 2006 can you give me any more info on this fuel filler neck? Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted February 27, 2006 Share Posted February 27, 2006 Nice to hear you are able to make some headway.Are you going to have to pull out the motor and use a bfh to make room for the turbo and piping?Good luck with that. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 27, 2006 Author Share Posted February 27, 2006 As far as the fuel filler neck, I dunno what it came off of. I do know it came out of a scrap bin behind the local GM dealership;) Jerry, as far as my turbo and exhaust, no BFHs were involved. Granted, I had to use it on the firewall to get the intercooler to fit right:headbang: Quote Link to comment Share on other sites More sharing options...
