abillings Posted February 27, 2006 Share Posted February 27, 2006 I have a 2001 Legacy with a nasty leak. Everytime it rains (which it rains 24/7 this time of year on the Oregon coast), water accumulates in the taillight region of the hatch door. Then when I open the door, the water flows out, making it very difficult to put anything into the car or take anything out. There was water INSIDE of the bulbs when I took them out to replace them. Is this a frequent problem with this model? Thanks Link to comment Share on other sites More sharing options...
brus brother Posted February 27, 2006 Share Posted February 27, 2006 This is a known issue. It is related to the rear taillight assembly. Use the search function and you should be able to locate it. I am up to my knees in alligators right now but will try and help in the search if no one else chimes in. Just chased the alligators out and found the following link. The SEARCH function is your friend on this site. Check this link from December. You are not alone. The information seems to point to inadequate sealant and gives suggestions as to how to remove the unit and reseal. http://www.ultimatesubaru.org/forum/showthread.php?t=48874&highlight=leaking+rear+gate There may also be mention at the NHTSA.org site under TSBs for Subarus of that or related years. Link to comment Share on other sites More sharing options...
abillings Posted March 1, 2006 Author Share Posted March 1, 2006 I have searched a couple of different sites, and it looks like I am going to have to remove and reseal the entire outside panel. Many of the posts were met with unsatisfactory replies to fix it or with replies from others who have the same problem. I don't want to take it to a dealership, because I know it will end up costing me a bunch of money and probably not even completely fix the problem. So if I were to reseal the outside panel, what sort of seal should I use? Is it something that I can get from an autoparts store or do I have to go to a dealership? Thanks Link to comment Share on other sites More sharing options...
