skybren Posted February 27, 2006 Share Posted February 27, 2006 I looked could not find any info. I have a 94 loyale 4wd auto. Can the 4at fit in the car easily or would it not fit at all. I am guessing if it would fit that the rpms would be lower. Is this a dream has anyone done this and again is it worth it and if so which subaru's have the 4at. I am just wondering whether it is a dream or not. thanks all in advance Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 27, 2006 Share Posted February 27, 2006 Since you said your Loyale as an auto, its probably going to be a 3AT which are garbage. The 4EATs came in the GL-10 wagons in '89, some '89 RX's like mine had, and a few other cars. As far as putting a 4EAT from a Legacy or a Impreza, too much to do to even worry about it. If you can find a 4EAT, it will bolt in HOWEVER, it is an electronic transmission instead of the mechanical like the 3AT so you'll need the tranmission wiring harness and the transmission computer as well. Link to comment Share on other sites More sharing options...
