aftermarket tach...
i now have a 1994 justy 2wd dl.
i noticed it doesn't have a tach in the instrument panel.how hard would it be to install one?
i'd really like to know the engine speed while driving the justy.
oh btw-why doesn't she have power steering.is it because she's a base model justy?
I don't know anything about wrneching on Justys. When I had a tercel wagon, I wanted to add a tach. The sr5 models had them so I figured it could not be that hard. I was told that there was a hook up on the distributor.
I don't know if any Justys got tachs. I also don't know if Justys had distributors, but I would guess they did.
I hope this helps somehow...:confused:
found out by a pm that it should be a easy hook up useing the wire from the dist going to the coil.i think the hardest part would be deciding were to mount the tach.
Or get a big ricey 12000rpm one that blocks your view and blinds you when its abnormally huge shift light goes off at the justys awesome redline:banana:
Yeah or not.....Pillar guages? On my Brat I put my tacho at the bottom of the pillar on the dash, easy to see and not in the way?
Just throwing some ideas out....
My soob has a tach but when I installed one on my Civic I mounted it on the steering column, not in the way of anything and easy to see. But if I didn't already have one in my soob, I'd buy an 'A' pillar guage cluster and mount it in the cluster on the A pillar. That would look the cleanest and is in good view. ~~Lucas
Sorry to get off topic but this reminds me of a 'wokrmate' with a triton, even tho he had tacho in his dash he installed a 6 inch monster tacho on the dash. Pft he also went to an exhuast shop and asked for a loud custom setup, so you know wot kind of person he was.
I believe you hook the seonsor wire to negitive side of coil or points breaker. You can also get the on power from the possitive side of coil.
yeah, that was the only problem:lol: it looked cool, but i could only see half of the speedometer and nothing else:lol:
For some reason I dont see an old sube needing the 2nd half of speedo as they dont go that fast.
