SuperRallyRoo Posted March 2, 2006 Share Posted March 2, 2006 I have a sagging problem on the right side of my car and I noticed when I changed the struts and shocks that the LR torsion bar is set with much less tension then the RR torsion bar. I tried to give it more tension by pulling it off and readjusting it but I couldn't get the bolt holes to line up. I figured you off road guys would know best sense most of you have reclocked the torsion bar for more lift. I just want stock ride hieght without the whole car sagging about 2" to the left. Link to comment Share on other sites More sharing options...
Qman Posted March 2, 2006 Share Posted March 2, 2006 You may have a bad torsion bar Matt. Considerring that your wagon shouldn't have had the bar reclocked. Pull one from PaP. BTW, did you get the Legacy home OK? Link to comment Share on other sites More sharing options...
SuperRallyRoo Posted March 2, 2006 Author Share Posted March 2, 2006 I took the bar out and it is fine... I had a replacement ready for it but it wasn't broken. So I dunno whats up with that. I'm thinking maybe it had just been removed at one point in its life and they installed it wrong? Anyway ya i got my wagon back in relatively same shape. They toasted my clutch pretty bad. But I only put a n/a legacy 2.2 disk in there. I think i'm going to go a little more beefy next time. Link to comment Share on other sites More sharing options...
Turbone Posted March 2, 2006 Share Posted March 2, 2006 And a kill switch? Link to comment Share on other sites More sharing options...
baccaruda Posted March 2, 2006 Share Posted March 2, 2006 I'm going to install a push-button ignition AND reverse the wiring on the ignition switch, so that you have to turn it CCW to start instead of CW. If someone turns the key the traditional way, the glovebox will eject a live rattlesnake into the passenger's seat. I will also scotchgard the driver's seat cushion to faciliate easy wipe-ups. Link to comment Share on other sites More sharing options...
