Meeky Moose Posted October 17, 2003 Share Posted October 17, 2003 i changed out all my bulbs last night, with the correct ones.. now the stinkin brake light warning light on the dash comes on when i step on the brake or turn on the lights.. any ideas?? i know they work cause i checked them twice... Link to comment Share on other sites More sharing options...
ShawnW Posted October 17, 2003 Share Posted October 17, 2003 Does your car have a high mount light that you forgot to make sure of? Link to comment Share on other sites More sharing options...
Meeky Moose Posted October 17, 2003 Author Share Posted October 17, 2003 nope, its an 84 hatch too btw.. forgot to mention that... Link to comment Share on other sites More sharing options...
Setright Posted October 17, 2003 Share Posted October 17, 2003 The circuit will light the dash warning light if ONE bulb is broken and the brake pedal is depressed. If both bulbs go, then the light will not come on. You may already know this, but it could help anyway... It sounds like there may be a current leak, from one of the bulb fittings. Either a wire is pinched or there is moisture in the lamp unit. Link to comment Share on other sites More sharing options...
Meeky Moose Posted October 17, 2003 Author Share Posted October 17, 2003 ok fixed this problem, one light was shuttin off when the brake pedal was pushed.. all i did was pull the bulb and turn it around and put it back in, seemed to have fixed it :brolleye: Link to comment Share on other sites More sharing options...
