mbrickell Posted March 4, 2006 Share Posted March 4, 2006 On the wiring diagram, there is a switch, wiper motor, and then some kind of control unit for intermittent wipers. I got the switch and motor from a junkyard car, but could not find anything that seemed to be an intermittent wiper control unit. If someone can tell me where this is specifically, thank you. oh, sorry, doh... 1990 Loyale 2wd stick wagon Link to comment Share on other sites More sharing options...
BobBrumby Posted March 4, 2006 Share Posted March 4, 2006 Should be under dash near the head light relays, well relays for something. Has 6 wires going to plug if the same as an ea81, it a little silver can. Also I didnot have to change my wiper motor but again its an ea81. Link to comment Share on other sites More sharing options...
kingbobdole Posted March 4, 2006 Share Posted March 4, 2006 I disagree... Mine on my 87 is on the removable panel directly below the steering column... when you take the covers off, theres that little box screwed to one that you have to unplug... sometimes I forget to plug it in... -------------------------------- ~Phil Only lowered FWD 5-speed XT-6 evAR 1987 Lifted "outback" Wagon 84 lifted BRAT kinda for sale Gen 1:32 "and on the end of the sixth day, God created signatures. And God saw that it was good." Rick plus RWD = Sweet Jumps Whatever one is harder to blow up. Link to comment Share on other sites More sharing options...
BobBrumby Posted March 4, 2006 Share Posted March 4, 2006 I disagree... Mine on my 87 is on the removable panel directly below the steering column... when you take the covers off, theres that little box screwed to one that you have to unplug... Since when was this not under the dash? As the dash is above the steering column and therefore under the dash is the removable pannel. Link to comment Share on other sites More sharing options...
