kingbobdole Posted March 4, 2006 Share Posted March 4, 2006 Ok, So I let Noss borrow my wagon and he told me that it puked up some coolant and was generally over heating but the gauge was still showing cold... so I thought he was nuts but went to wally land and baught some cheesy gauges and put them in anyway... It came with a oil pressure, coolant temp and Amp gauge, 2 of which I have hooked up.. the old pressure I sneaked into the turbo light port and retained the stock gauge. Then to hook up the coolant temp I actually pulled the stock sender and replaced it with the new sender... All in all the install went good, except when I forgot to tighten the gauge end of the oil pressure gauge:eek: Ok, now for the questions.. on the temp gauge it barely gets to 190... but Ronis XT Turbo rides at about 210 all the time... is 190 about par for my 87 SPFI? Two... My oil pressure when its cold and being revved will shoot off the gauge to like over 100 psi... but then when its warm it'll go to 80 and then gerk down to 60 (which I'm sure its supposed to do) and trouble with this high oil pressure... Lastly.. Wheres a good place to hook up the AMP gauge? Thanks! Mmmmmmmm clean wagon -------------------------------- ~Phil Only lowered FWD 5-speed XT-6 evAR 1987 Lifted "outback" Wagon 84 lifted BRAT kinda for sale Gen 1:32 "and on the end of the sixth day, God created signatures. And God saw that it was good." Rick plus RWD = Sweet Jumps Whatever one is harder to blow up. Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted March 4, 2006 Share Posted March 4, 2006 If the amp meter is anything like a regular multimeter they need to be hooked in series with the possitive or negative battery cable. Quote Link to comment Share on other sites More sharing options...
Indrid cold Posted March 4, 2006 Share Posted March 4, 2006 Nice...very nice looking wagon... love the tinted winders, sharp tires, crisp...baby... crisp sorry can't help with ?. Quote Link to comment Share on other sites More sharing options...
jeffast Posted March 4, 2006 Share Posted March 4, 2006 nice mate now that it's warming up you wanna go wheelin some time soon? Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted March 4, 2006 Author Share Posted March 4, 2006 Thanks... I love the way my wagon looks too, even matte.. The best time is right after I've washed it and the white letters on the tires are really white again. I always appreciate comments on it... As far as the amp gauge goes, you are right it need to be hooked up "in line" but I'm not sure wheres the best place... I actually ran the wires through the firewall and was corn-fues on what to disconnect to run these through, so I stopped and decided to ask the best of all places..... Jeff... I'm EXTREMELY BUSY at the moment trying to find time to prep the 6 for the trek to The Dragon... but we could probably find some time to break some things. Maybe not this month, but soon -------------------------------- ~Phil Only lowered FWD 5-speed XT-6 evAR 1987 Lifted "outback" Wagon 84 lifted BRAT kinda for sale Gen 1:32 "and on the end of the sixth day, God created signatures. And God saw that it was good." Rick plus RWD = Sweet Jumps Whatever one is harder to blow up. Quote Link to comment Share on other sites More sharing options...
jeffast Posted March 4, 2006 Share Posted March 4, 2006 you know i have no life just let me know a week ahead of time when it's good for you Quote Link to comment Share on other sites More sharing options...
rllywgn Posted March 4, 2006 Share Posted March 4, 2006 ok just a couple questions, I just got the same gauges but larger (2") and installed them on my 88 mpfi turbo sedan.. I ran into a problem on my oil gauge only in the sense that i pulled the wrong sensor out of the oil pump, my car didnt come with an oil pressure gauge but has an oil pressure switch and a plug where the oil pressure sensor should be... so to the point... it looks like your oil pressure sensor is there but the pressure switch is not? or is that just a difference between cars with and without oil gauges from the factory? is your temp sensor mounted near the t-stat housing? if not.. that may have something to do with your temp readings being off a lil.. i think it came out very well... nice... rllywgn Quote Link to comment Share on other sites More sharing options...
hush777 Posted March 4, 2006 Share Posted March 4, 2006 Ok, now for the questions.. on the temp gauge it barely gets to 190... but Ronis XT Turbo rides at about 210 all the time... is 190 about par for my 87 SPFI? Two... My oil pressure when its cold and being revved will shoot off the gauge to like over 100 psi... but then when its warm it'll go to 80 and then gerk down to 60 (which I'm sure its supposed to do) and trouble with this high oil pressure... Lastly.. Wheres a good place to hook up the AMP gauge? Thanks! Get some heavy guage wire 6 or 8 then run two pieces from the battery area into your guages. Disconnect the small wire that goes from the battery to the fusable links and hook one end up there and the other up to where the small one came off the battery. Don't start the car but turn the key and lights on. Look at the guage and it should show discharge. If not reverse the wires. Start the car and it shoud read just a bit above 0. Hush Quote Link to comment Share on other sites More sharing options...
Durania Posted March 4, 2006 Share Posted March 4, 2006 Thats a sweet yellow XT in the back. Quote Link to comment Share on other sites More sharing options...
Cougar Posted March 4, 2006 Share Posted March 4, 2006 The end of the wire that you remove from the battery to hook to the amp gauge will be the positive or charge end. For safety, I would recommend you install about a 100 amp fuse in the line at the battery connection. This wire to the amp gauge will be hot at all times and if it gets shorted somehow without a fuse to protect it, there will be a real quick problem in the wiring and maybe a fire in your car. I prefer a voltmeter to watch the charging of the battery. It is easier to install and safer. The temperature sounds fine as it appears you have a 190 degree thermostat installed and would guess that this is the correct one to use in your car. I would be more concerned about the other car. It sounds like it may be a little too high. Quote Link to comment Share on other sites More sharing options...
Turbone Posted March 4, 2006 Share Posted March 4, 2006 Be careful of the plastic oil pressure line. If it rubs on anything or is close to a heat source, you could have a real mees on your hands. If you get some extra $ and time, run copper line for it instead. Nice wagon:headbang: Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted March 4, 2006 Share Posted March 4, 2006 Be careful of the plastic oil pressure line. If it rubs on anything or is close to a heat source, you could have a real mees on your hands. Already had that problem. Kingbobdole, the readings you are reporting sounds appropriate for your car. My wagon will get very high oil pressure when its cold, but I try to not rev it up when it is cold. The oil temp will be around 225 cruising on the freeway. I still need to hook in my water temp gauge though Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted March 6, 2006 Author Share Posted March 6, 2006 I knew the AMp gauge was kinda dangreous, so I've been thinking about not hooking it up... Thanks everyone else that had suggestions on my car, it really helps... I ran into a problem on my oil gauge only in the sense that i pulled the wrong sensor out of the oil pump, my car didnt come with an oil pressure gauge but has an oil pressure switch and a plug where the oil pressure sensor should be... so to the point... it looks like your oil pressure sensor is there but the pressure switch is not? or is that just a difference between cars with and without oil gauges from the factory? Kinda, I think I understand what you are asking... but basically on the pic, where I mounted the cap. tube for the new gauge is where the indicator for the light is on turbo cars or cars with out gauges... Mine had a plug... the big round thing below it is the original sender still in place running the gauge on my dash. Thats a sweet yellow XT in the back. Thanks.... just wait till June... I'll be vicious:dead: Quote Link to comment Share on other sites More sharing options...
rllywgn Posted March 6, 2006 Share Posted March 6, 2006 ahh that makes sense.. i wonder if mine has any ecu function (oil pressure switch) or if its just there for the oil light, ill just unplug it... but i dont know the consiquences of that.. also i cant find an adaptor to fit the plugged hole anyway.. rllywgn Quote Link to comment Share on other sites More sharing options...
jeffast Posted March 6, 2006 Share Posted March 6, 2006 Thats a sweet yellow XT in the back. all hail the cheese wedge Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted March 6, 2006 Author Share Posted March 6, 2006 ahh that makes sense.. i wonder if mine has any ecu function (oil pressure switch) or if its just there for the oil light, ill just unplug it... but i dont know the consiquences of that.. also i cant find an adaptor to fit the plugged hole anyway.. rllywgn IIRC the oil pressure is controlled mechanically... the indicator is ONLY for the light on the dash... My wagon didnt come with one since I had a guage stock... so you are safe to unplug it... need a plug? just go to a yard and find a car with a gauge... theres on in there... I have a few of them if you like too Quote Link to comment Share on other sites More sharing options...
rllywgn Posted March 6, 2006 Share Posted March 6, 2006 i had it plumbed into the pressure switch location for a couple days with no problem.. disconnected after i discovered it wasnt the sensor, atleast until i find out if its safe to run or not that way.. adaptor does fit that hole rllywgn Quote Link to comment Share on other sites More sharing options...
