subestyle18 Posted October 18, 2003 Share Posted October 18, 2003 This is an 83 gl wagon with a carbed ea81. I bought the car and it ideled a little high(1500 or so) i needed to pass emissions so i went to turn the idel down. When i did that the car would die when i would let the idel below 1200rpms or so. So i turned the idel back up so that it wouldnt die. Now when ever i start the car it idels at 3000rpms and then when i warms up it dies when you are off the gas. I think the high idel when you start is some kind of choke problem. The guy i bought it from said he thought there was a vacume leak so i am going to start replacing hoses. Any help you can give me will be greatly appreicated. Thanks David Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 18, 2003 Share Posted October 18, 2003 hello and welcome to the board. Well from the sounds of it, it could either be your acellerator pump which is located in the carb or it could be a vacuum leak. I had an 83 hatchback that was carbed and it had the same problem. I took my time and cleaned the carb really good and cleaned out the acellerator pump too. If its the 1-barrel Carter-Weber carb *cough* crappy *cough* there is also a little itty bitty tube that runs from the acellerator pump to the barrel. Mine had a hole in it so it would not get enough fuel and start crapping out on me. If your tube has a hole in it, I have some that I can get you for 50 cents per piece. Also, there is are lots of board members who live in your neck of the woods. I know Edrach lives in Woodinville too and he's a very nice guy to get ahold of when you're having problems. Anyways, I hope this helps and welcome again to the board! Link to comment Share on other sites More sharing options...
subestyle18 Posted October 26, 2003 Author Share Posted October 26, 2003 I am just checking. My 83 4wd wagon with the ea81 should have the hitachi carb on it. I am going to start look for vacume leaks, by just going through and replacing the hoses. If any one has any tips on this that would be great. Thanks david Link to comment Share on other sites More sharing options...
calebz Posted October 26, 2003 Share Posted October 26, 2003 Also check for vacuum leaks around the intake manifild by spraying carb cleaner around all the sealing surfaces.. if idle increaes, you found a leak. Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 26, 2003 Share Posted October 26, 2003 whmy simmilar idle problem w/spfi? should i use the same ethods described above. Feel free to elaborate. Link to comment Share on other sites More sharing options...
