overunder Posted March 6, 2006 Share Posted March 6, 2006 when I let out the clutch on my 81 brat its starts to ingage and then it just slips. I assumed that the clutch was just warn out so I bought a kit and replaced the disk, bearings and pressure plate but it still is doing the same thing. Any ideas on what I should look at next? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 6, 2006 Share Posted March 6, 2006 Clutch cable adjusted properly? Did you have the flywheel turned by a competent shop? GD Link to comment Share on other sites More sharing options...
overunder Posted March 7, 2006 Author Share Posted March 7, 2006 yeah the clutch cable seems to be in the right spot and I did have the flywheel machined. I tried tightening the cable all the way as well as loosening it all the way and it didnt really seem to have much of an affect on it. When the problem first occured it was accompanied by a buzzing/whirring/rattling noise only when the clutch pedal was released. The pressure plate that I took out had a pretty deep groove from the release bearing. Link to comment Share on other sites More sharing options...
SUBARU3 Posted March 7, 2006 Share Posted March 7, 2006 I wonder if your clutch is fine and you have an internal transmission failure??? This sounds very supicious of that. Todd Link to comment Share on other sites More sharing options...
overunder Posted March 8, 2006 Author Share Posted March 8, 2006 I was worried about that. Any ideas on how i could know for sure? And also if I need to replace the one I have will any EA 81 4 speed transmission work or do they vary from model and year. Brandon Link to comment Share on other sites More sharing options...
overunder Posted March 10, 2006 Author Share Posted March 10, 2006 okay so you were right, its not the clutch at all. I put the car into 4 wheel drive today and it drives just fine but when I slip it back into two wheel drive it just spins. I really wish I would have tried this before I replaced the clutch but I am new to this game and hindsight is 20/20. Im just stoked that I put the clutch in right. Any ideas on exactly what the problem is and what my next step should be? Link to comment Share on other sites More sharing options...
DaveAP Posted March 10, 2006 Share Posted March 10, 2006 okay so you were right, its not the clutch at all. I put the car into 4 wheel drive today and it drives just fine but when I slip it back into two wheel drive it just spins. I really wish I would have tried this before I replaced the clutch but I am new to this game and hindsight is 20/20. Im just stoked that I put the clutch in right. Any ideas on exactly what the problem is and what my next step should be?You could have a front axle spline wearing out Link to comment Share on other sites More sharing options...
overunder Posted March 10, 2006 Author Share Posted March 10, 2006 excuse my ignorance but when I had the car off the ground and turned the front axel by hand only the passenger side wheel would turn even though both axels turned. Is this normal or could that be part of the problem. Brandon Link to comment Share on other sites More sharing options...
waimaks Posted March 10, 2006 Share Posted March 10, 2006 Both axels turn but only one wheel? I'm no expert either, but that does sound like something inbetween axle and wheel-hub etc, and not in the gearbox. Good luck! Got any parts cars near by? Link to comment Share on other sites More sharing options...
overunder Posted March 10, 2006 Author Share Posted March 10, 2006 unfortunatly I dont have a parts car. Hey Im pretty sure I went through waimana on my way to go hike in the urewera's. cool area for sure Link to comment Share on other sites More sharing options...
Skip Posted March 10, 2006 Share Posted March 10, 2006 You typed "I had the car off the ground and turned the front axel by hand only the passenger side wheel would turn even though both axels turned. Is this normal or could that be part of the problem." If this is the case it looks like the splines that connect the driver's side axle to the hub (part that drives the wheel) are stripped. Here is a test, have the hood open, engine running, 2wd. Stand beside the car on the driver's side and look at the axle. Have a mate engage first gear and let out the clutch. IF the axle turns and the car does not move, you will need a hub and an axle as the spinning has probably knackered both. Hope this helps, good luck Link to comment Share on other sites More sharing options...
SUBARU3 Posted March 10, 2006 Share Posted March 10, 2006 I concur with Skip! Even if only one side is bad, the car will not move forward, as the bad side would be the path of least resistance. Todd Link to comment Share on other sites More sharing options...
Snowman Posted March 10, 2006 Share Posted March 10, 2006 Yup, I would bet money that Skip is right (as usual;) ). I had the same thing happen on a friend's 88. I replaced the clutch, thinking it was toast, but the car would only go in 4wd. Turns out, the splines in the left front hub were totally gone. Take a long, hard look at the axle as well as the hub, as both may be damaged. Link to comment Share on other sites More sharing options...
waimaks Posted March 11, 2006 Share Posted March 11, 2006 unfortunatly I dont have a parts car. Hey Im pretty sure I went through waimana on my way to go hike in the urewera's. cool area for sure Wow, small world huh!Do you frequent NZ? If you are ever in Waimana again, look out for the beige gen one brat and silver xt, The only ones in the district! Good luck with the hub it seems! Link to comment Share on other sites More sharing options...
overunder Posted March 11, 2006 Author Share Posted March 11, 2006 yep you guys are right. I pulled the hub off and it was ground completly smooth on the inside. Thanks for the help. What hubs would be compatible. The local junkyard said that they had a couple of 81 subarus. Are the hubs generic enough that this would work? Brandon Link to comment Share on other sites More sharing options...
michael appel Posted March 13, 2006 Share Posted March 13, 2006 It is internal damage bushings and bearings buy a new tranny and good luck been there done that mike Link to comment Share on other sites More sharing options...
Skip Posted March 13, 2006 Share Posted March 13, 2006 Michael, Thanks for the input. Please read the last five posts before yours. Link to comment Share on other sites More sharing options...
