bella Posted March 6, 2006 Share Posted March 6, 2006 Please someone tell me what calibre(internal) has well cylinder for subaru Leone, 1986, sedan, EA82. I thing my local dealer tell me there is 17.5 mm...Is correct? Thanks. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted March 6, 2006 Share Posted March 6, 2006 Hello. Do you want to know the thickness of the brake rotor(disc)? Link to comment Share on other sites More sharing options...
bella Posted March 6, 2006 Author Share Posted March 6, 2006 Hello. Do you want to know the thickness of the brake rotor(disc)? Sorry my english but I whant to now diameter of well cylinder so also the diameter of pistond how are inside.I hope this details will help you. 10x. Red lines are pointed to required dimensions..........noweone????:headbang: Link to comment Share on other sites More sharing options...
Subarian Posted March 6, 2006 Share Posted March 6, 2006 I would recommend you check yours before ordering, as I have run across at least two sizes on the rear brake cylinder. My current one is about 19mm. The size may be cast or stamped onto the cylinder. Link to comment Share on other sites More sharing options...
bella Posted March 6, 2006 Author Share Posted March 6, 2006 I would recommend you check yours before ordering, as I have run across at least two sizes on the rear brake cylinder. My current one is about 19mm. The size may be cast or stamped onto the cylinder. 10x man but I don't have time to do this.....so I'll still wait from USMB members an answer. Link to comment Share on other sites More sharing options...
bella Posted March 6, 2006 Author Share Posted March 6, 2006 Haynes manual can help mee with this??? Link to comment Share on other sites More sharing options...
wounded brat Posted March 6, 2006 Share Posted March 6, 2006 Ever go surfing on the black sea? 10x Link to comment Share on other sites More sharing options...
bella Posted March 6, 2006 Author Share Posted March 6, 2006 Ever go surfing on the black sea? 10x No man...sorry....surfing is not very popular here. Link to comment Share on other sites More sharing options...
Subarian Posted March 6, 2006 Share Posted March 6, 2006 Raybestos also lists a 3/4 inch (roughly 19mm). Link to comment Share on other sites More sharing options...
bella Posted March 7, 2006 Author Share Posted March 7, 2006 I've heard from someone with motor service that ONLY Subaru Wagon has 19 mm whell cylinder and Sedan(like mine) has 17.5 mm. Now, what do you thing? Thank you. Link to comment Share on other sites More sharing options...
Subarian Posted March 7, 2006 Share Posted March 7, 2006 Bendix also lists 3/4 for the 4dr sedan, BUT TrueTorque lists either 5/8 (15.9mm) or 11/16 (17.5 mm) for the 4dr sedan. If you're getting new or remanufactured cylinders, the difference won't matter as long as you get both the same. If you're looking for a rebuild kit, you're probably going to have to pull yours out to be 100% sure. Keep in mind that these specs are also for US Domestic Market Subarus; the European specifications may be different. Link to comment Share on other sites More sharing options...
bella Posted March 9, 2006 Author Share Posted March 9, 2006 Bendix also lists 3/4 for the 4dr sedan, BUT TrueTorque lists either 5/8 (15.9mm) or 11/16 (17.5 mm) for the 4dr sedan. If you're getting new or remanufactured cylinders, the difference won't matter as long as you get both the same. If you're looking for a rebuild kit, you're probably going to have to pull yours out to be 100% sure. Keep in mind that these specs are also for US Domestic Market Subarus; the European specifications may be different. Thanks man.....I'll buy 2 pcs. to be sure. Wheel cylinder successfully changed, and are 17.5 mm diameter. Thank you all. Link to comment Share on other sites More sharing options...
