welded diffs
Yeah - I have my rear welded - a lot of us with lifts do it. You just weld the spider gears together - I put a high grade bolt in the geer teeth and weld it all together.
As for on-road, if the pavement is dry, you'll snap the stock rear axles on a hard turn. The DOJ cups will split open.
BUT - the cool thing is that it takes only a few short minutes to remove one axle for pavement driving. I've driven with them in mind you, you just have to be careful not to turn too hard or fast.
