HATCHY Posted March 8, 2006 Share Posted March 8, 2006 Im wanting to drop on weber onto my EA81 but im not sure which weber to use.. IS it the 32/36 there is so many I would like to know if this is the right soze? or if someone can tell me where they got theres or something... please help:confused: :confused: Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted March 8, 2006 Share Posted March 8, 2006 Yes you will want the 32/36 DGV or DGEV.If you do a search you will find quite a bit of info on them.You can get them from Redline or carbs unlimited.I know there is plenty of info to be had.The real question is weather or not you want one you will have to rebuild or one that is set up and ready to go.Good luck. Quote Link to comment Share on other sites More sharing options...
Subarian Posted March 8, 2006 Share Posted March 8, 2006 The DGAV is water choke; the DGEV is electric. I recommend the DGEV because it's easy to wire (one wire) and it's very reliable. I've got close to 80,000 on mine. Quote Link to comment Share on other sites More sharing options...
