wandersub Posted October 18, 2003 Share Posted October 18, 2003 i am working on the removal of the automatic transmission from my 2001 forester i have removed what i think are all of the bolts, i count 5 bolts and two nuts leaving two studs at approx the 4 and 8 o'clock positions. i removed 4 bolts from the torque converter mounting and the aft transmission mount is free. i can not seem to get the engine and tranny to seperate i have tried everything i can think of. if i releave preassure on the tranny jack the whole engine pivots as one unit. there is no sign of seperation anywhere. HELP PLEASE!!!! Link to comment Share on other sites More sharing options...
Phillip Posted October 19, 2003 Share Posted October 19, 2003 Seperating the engine from the transmission when removing the engine from my 1999 Outback was also quite difficult. The two dowl pins (pressed into the block) were frozen tight in the trans case from electrolysis. Penetrating oil and vulgar language did nothing to break it free. I finally lifted the tailshaft of the trans with a floor jack, creating a small gap between the trans and engine on each side. I CAREFULLY slid in a thin putty knife on each side of the gap and raised & lowered the jack repeadedly. Slowly I was able to insert the putty knives further and further in the growing gap between the engine & trans (use thicker scrapers as the gap widens). I spent a good 2-3 hours seperating the engine from the trans. CAUTION: you WILL break the transmission case or block if you apply enough uneven force! If you try this, make DARN SURE you've got all the engine to transmission bolts removed. Hopefully someone else will know a quicker & easier trick, if not, take your time and you'll get it. Link to comment Share on other sites More sharing options...
wandersub Posted October 20, 2003 Author Share Posted October 20, 2003 Just wanted to post a quick thanks. We finally got the transmission off with a little bit of gentle prying and pulling. Of course once we got it off I found my problem was much worse than I had hoped:boohoo: Oh well, on to find a used transmission. Thanks again. Link to comment Share on other sites More sharing options...
Sweet82 Posted October 20, 2003 Share Posted October 20, 2003 Get one from Az! They are Dual Range down under! For what it's worth, Glenn 82 Hatch, has D/R tranny. 01 Forester, wants a D/R tranny.:madder: Link to comment Share on other sites More sharing options...
leaksoilknocksclutch Posted October 20, 2003 Share Posted October 20, 2003 WOW, a 99 and a 01 that have tranny issues? YIKES!! Link to comment Share on other sites More sharing options...
wandersub Posted October 23, 2003 Author Share Posted October 23, 2003 The only reason my '01 has a trannie issue is because an oil change place partially drained my differential fluid when doing an oil change. Can't prove it but I'm pretty sure that's what happened. My guess is some kid started draining the diff fluid and stopped once he realized it wasn't oil. He probably then drained my engine oil and never topped off the diff. I then proceeded to drive ~800 miles towing a boat like that! Learned my lesson! Link to comment Share on other sites More sharing options...
