TROGDOR! Posted October 19, 2003 Share Posted October 19, 2003 So... here we go... clean looking cup holders for the EA82!!! Unfortunately you have to have the aftermarket stereo plate to make this work. Since this works in EA82's with the plate, it'd probably work in EA81's as well. Know that half-side dummy plate that's under the main hole for the stereo? This cup holder uses the hole for it. You need to use the cup holder unit out of a 1991-94 Nissan Sentra. It basically consists of a mounting sleeve that holds a sliding cup holder assembly. If you can find a car at the yard with the vent panel off, this cup holder comes off with only 2 screws. It's located below the heater/AC controls. Before installing this in the car, you need to do a few things. The sliding mounting collar- it needs to come off and be flipped over, then slid back on. You want the sides with the mounting holes to be flush with the back of the stereo plate. You'll also need to trim some plastic off the corners of the mounting holes, so they will clear the screw posts on the stereo faceplate. The cup holder has a couple little wire brackets on top that flip down so you can put those little Japanese soda cans in it. There won't be enough room to flip them up for American drinks once the holder is mounted. Pop those suckers off and get rid of them! Once you have the cup holder screwed onto the back of the mounting plate, you'll have to modify the stereo brackets on the car. As you know they taper inward on the bottom, where the plastic cubby hole mounts. You need to either cut off the bottom of these brackets, or bend the bottom out of the way, as the cup holder is a good 3/4 inch wider than the cubby hole. Then just screw the stereo plate on, and that's it! Pics: It'll be a little hard to work the stereo controls with cups in the holder, but hey, it's worth it IMO. Clearance is OK with an automatic, the stick may come VERY close to the holder in a manual. You may have to put a couple washers on your screws and move the holder farther back into the dash. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 19, 2003 Share Posted October 19, 2003 I can tell you for sure that there's not enough clearance for that in a manual EA81. Don't know about the EA82's tho. I've tightened up the shifter real good, and there's still not enough. Maybe if you angled the shifter backwards a bit - like bent the rod. GD Link to comment Share on other sites More sharing options...
archemitis Posted October 19, 2003 Share Posted October 19, 2003 race cars dont have cupholders, so obviously neither do subarus. it just wouldn be rite. i can set coffee on the dash of my ea82 when the axles are good. Link to comment Share on other sites More sharing options...
the_bard Posted October 19, 2003 Share Posted October 19, 2003 I put mine just to the left of the emergency brake lever. There was just enough to room to mount the cup holder there, and so far it's held. I'll get a pic or two up of it when I get around to it :-p Link to comment Share on other sites More sharing options...
Snowman Posted October 19, 2003 Share Posted October 19, 2003 Since I got my subaru, I've been using one of those cup holders that rests on the lip on the top of the door. It works great when I'm on paved roads. The setup that you made definitely looks cool and functional, and I probably try it if I had an auto. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 19, 2003 Share Posted October 19, 2003 I'm just remembering what one of the mechanics in my National Guard unit did for his drink in a 2 1/2 ton truck. The doors are perfectly flat on top, and just made from painted steel. He used a magnet from a speaker, and a steel enameled coffee cup. hehehe worked pretty good too. And looked hella funny going down the freeway - with a coffee cup sitting on the door. Looked like it was about to fall out. GD Link to comment Share on other sites More sharing options...
Turbone Posted October 19, 2003 Share Posted October 19, 2003 I have an adjustable holder in my 86 Turbo wagon. Its on the center console between the e-brake and driver seat, it just fits. Of course its a 5spd PB 4WD, so theres no D/R lever to get in the way. Rob Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted October 19, 2003 Share Posted October 19, 2003 i just took one of those cheap little cup holders that slides into the window area on your door.i cut the angle off of it so that it was flat. i then drilled two hole and screwed it to the dash. holds just fine and doesn't require much work . first performance mod i did to my wagon. don't be this guy:drunk: holding your beer like a sucker. get a cup holder:headbang: Link to comment Share on other sites More sharing options...
WagonsOnly Posted October 19, 2003 Share Posted October 19, 2003 I'm pretty sure the cubbyhole in EA81s is quite a bit smaller than EA82s...you'd have to remove everything in the center dash panel to mount that. Ashtray, and radio, or the balance control for the stock stereo would have to go and quite a bit of cutting would be required. I think it's a little too close, even for the AT shifter, too. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 19, 2003 Share Posted October 19, 2003 Nope - that radio adaptor fits just fine: (your right about the cutting tho) http://usmb.net/gallery/albuo56/84_wagon_deck That's my car BTW. I just don't think the cup holder would have enough clearance with the shifter while open - unless you bent the shifter rod backwards. GD Link to comment Share on other sites More sharing options...
JonOfScio Posted October 19, 2003 Share Posted October 19, 2003 I've got an '88 manual hatch, and there is space for 20oz and smaller drinks to fit in the open console space behind the e-brake. Link to comment Share on other sites More sharing options...
MilesFox Posted October 19, 2003 Share Posted October 19, 2003 toss the cups on the guy who threw a bottle out as he passed you!(you should have been there!) Link to comment Share on other sites More sharing options...
WagonsOnly Posted October 19, 2003 Share Posted October 19, 2003 GD, the interlock button on the auto tranny (and the plasticy stuff the stalk is made of) would prevent bending the AT shifter for the cupholder. You'd probably have to replace the entire top half of the shifter with something bent back towards the rear of the car, and relocate or rewire the button. I think bending the metal shifter rod on the manual would be easy enough though--assuming you wanted to do all the cutting work on the center of the dash. Link to comment Share on other sites More sharing options...
AKIRA Posted October 19, 2003 Share Posted October 19, 2003 "race cars dont have cupholders, so obviously neither do subarus. it just wouldn be rite." - archemitis The Bricklin SV-1 didn't have a cigarette lighter, because of safety reasons, I freak'in kid you not, read it here:Bricklin page read it! Link to comment Share on other sites More sharing options...
moosens Posted October 20, 2003 Share Posted October 20, 2003 For EA82 cars maybe try getting an ashtray that you don't care about and modifying it.Cupholder will then slide in and out. Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted October 20, 2003 Share Posted October 20, 2003 Hey General, sure your not in my unit? I do that with my stainless coffee cup on my duece. I've also gone as far as making up a metal loop that a 1L of Mt. Dew fits into nicely and that hooks into my magnet and holds the Dew nicely. (I drink Dew way more often than coffee, in fact, I've been told by many that my blood is prolly green). As for cup holders in my cars, wouldn't work, the only cup I use is a 64oz Circle K or 7-11 cups, and I haven't found a cup holder on the market that fits them. (have one that holds my cup in the Brat that I made, don't wanna mess with the HT to do that though). Link to comment Share on other sites More sharing options...
WagonsOnly Posted October 20, 2003 Share Posted October 20, 2003 AKIRA: Malcolm Bricklin went from importing Fuji Rabbit scooters (unsafe) to Subaru 360s (deathtraps) to the SV-1 (supposedly safe) to the YUGO (definitely safe unless, by some freak of nature, you got it started). The Bricklin even locked you inside the car if the battery died! (Power gullwing doors and power windows were NOT a good combination.) Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2003 Share Posted October 20, 2003 Hehe. I'm in the 141 Support BN. up here in Portland. I'm a mechanic (52D, but I do mostly 63b stuff). I'm getting out (medical), but we'll have to chat sometime. GD Link to comment Share on other sites More sharing options...
AKIRA Posted October 20, 2003 Share Posted October 20, 2003 lol. that is friggin hilarous! the battery dies and you rump roast isn't getting out soon! I did know about what else he imported, actually a year ago he tried to import another yugo like car, started with a Z? Link to comment Share on other sites More sharing options...
WagonsOnly Posted October 21, 2003 Share Posted October 21, 2003 He tried importing the new Yugo Koral (based on the old GV, which in turn was based on the '70s-era Fiat 128) and the all-new Florida. The "Z" comes from the parent company, Zastava Yugo Ltd. of Serbia and the new subdivision, Zastava Motor Works of the United States. I don't know if he ever got the new cars to pass the Federal safety standards, but I'm sure if there's some way he can get them in here he will. The Yugo name, incidentally, will not be used in the United States. I guess it still has the same connotation as "Pinto" or "Pacer". Link to comment Share on other sites More sharing options...
AKIRA Posted October 21, 2003 Share Posted October 21, 2003 or Edsel:D AK Link to comment Share on other sites More sharing options...
moosens Posted October 21, 2003 Share Posted October 21, 2003 But just remember this is America and if the cars have cupholders he'll sell a million of them. Link to comment Share on other sites More sharing options...
WagonsOnly Posted October 21, 2003 Share Posted October 21, 2003 Precisely why the Pacer did better than the Pinto, Edsel, Yugo, Gremlin...you could get one with a center console. Link to comment Share on other sites More sharing options...
bbbs53 Posted October 21, 2003 Share Posted October 21, 2003 Actually, the "Brick" was a pretty inovative car. They only made 2585 of them and 1500 of them are still around. As far as getting out goes, most have been converted to air instead of hydraulic lift for the doors and the electric solinoids have been replaced with air actuators. You could always crawl out of the back hatch. The guy is also famous for the 2000.00 dollar EV Warior bicycle. Another venture that went the way of the Yugo. He worked on a 12 cylinder rotary engine with a man named Turner that only had 147 moving parts and weighed half of a V-8, producing 500 ponies. Early use of radical technology, acrylic over fiberglass, and a complete integral roll cage, molded in safety only colors, yellow, red, orange, white and suntan. The guy blew 32,000,000 million of the Canadians money building them. They sold in 1974 for $10,000. They cost more than 13,000 each to make. The later ones had Ford running gear in them and could be made pretty fast. Average selling price today, 6 to 30 thousand. Link to comment Share on other sites More sharing options...
CamoMan Posted July 7, 2005 Share Posted July 7, 2005 Heh, i had a friend who totalled his Yugo by hitting a pothole. Haha, it bent the frame, i think the insurance co. only gavem $1000 and it was only a few years old. Link to comment Share on other sites More sharing options...
