Is that frappicino, or frothy oil???
Changed the oil in my 94 Loyale last night and noticed that the underside of the oil cap was the frothy oil that makes me think head gasket. The oil coming out of the pan was just fine though.
Do I have to worry about an impending, catastrophic failure or should I just keep driving until it makes itself something to worry about?
YEP! That is, in my experience, the tell-tale sign for a blown gasket. Might as well start gathrering parts, clan out the garage, and get ready for some wrenching.
AAARRRGGGH! :banghead:
The body doesn't warrant a rebuild (rust)... I'll drive it until it dies and part it out/scrap it. What is the failure? Can I expect a deterioration or will it give up all of a sudden?
I agree with Jim (86Subaru) condensate can
form on the cap. Lots of my Roo's have it.
(I own and operate about ten)
Not a concern
NOW bubbles in the rad
coolant out the overflow
different matter
Having a leak down test performed on the coolant
system is the only real test.
:lol: I once had "frapacino" all under the lid and all over the inside of the rocker covers. One bottle of GOSS chem-i-weld (there are other similar brands) into radiator repairs the water passages. After thinking HG change, new motor , etc. Ended up driving car to sydney (3000 km) and then for six months, then sold car and the bloke that has it is still driving it. Not bad for a ten dollar bottle of goo. Would often see steam out exhaust in mornings as condesate is turned into steam.
I found "froth" on my oil fill cap too for a while when it was cold. I just wiped it off and haven't had a problem. No sign of oil or antifreeze where it doesn't belong - except a drip or two on the driveway. A little bit of it belongs there, doesn't it? :rolleyes:
