86subaru Posted October 19, 2003 Share Posted October 19, 2003 hello all, i have 88 a/t full time 4wd turbo wagon , can i use a regular size radiator or should i use a heavy duty double row one? no off roading just daily use :wave: Link to comment Share on other sites More sharing options...
TomRhere Posted October 19, 2003 Share Posted October 19, 2003 Bigger is better, in this case, Jim. Especially with a turbo on there. You have alot more heat being dumped back into the engine. Price differance betwen the 1 and 2 row radiators, isn't that much, for a new one. So I would put the 2 row in, just to save future headaches. Got a new 2 row in the '86. Bought it last year, on-line for $109.00 to my door. The price has gone up this year, thinking it's now around $125.00 plus S&H. I'll be getting one for the '82 here shortly. Nothing wrong with the one in there now, just going to do it. Link to comment Share on other sites More sharing options...
86subaru Posted October 19, 2003 Author Share Posted October 19, 2003 ok, the one in the turbo 4wd wagon was ok, but PRETTY HARD TO GET OUT , and looked bad , so we put a good regular one , surely it would be ok to run it until next spring , thanks :wave: Link to comment Share on other sites More sharing options...
camot Posted October 21, 2003 Share Posted October 21, 2003 You WILL overheat. The turbo rad will dump a whole lot more heat and believe me, the turbo puts out lots of heat. You will also notice that there is a coolant line to the turbo itself (that's why the turbo water pump is different) and if you overheat, it will cook the oil in the turbo and freeze the floating sleeve bearing that the turbo runs on. Not pretty. Link to comment Share on other sites More sharing options...
MilesFox Posted October 21, 2003 Share Posted October 21, 2003 jim, i got my car running with thos spare parts you gave me! she rund like a scalded dog, but still dooks a little bit when warm. anyways, it has a single row radiator, and i went around beating down some county roads last night. the radiator kept her right in the temp range, smack in the middle i think you should be ok, since mine stays cool while romping it. Link to comment Share on other sites More sharing options...
