What's Left To Mod For Offroad?
Jibs
I've been thinking of doing this on my Forester for the rear e-brake. I tried searching with no luck, so does anyone have any install tips or links?
I installed a turning brake like they use on sandrails it hooks up to the hydrolic lines , for the rear brakes , get the one with the smaller pistons for more force,
LSD does not compete with the welded rear end.
Not even close. Removing an axle or more likely
installing an axle before wheeling is not a big deal.
Driving with a welded diff is not as bad as I thought
it would be. I have noticed a little more wear on my
back lugs since I decided to leave my axle in all the time.
If you weld the diff right...you'll never break it.
You may break other things but the spider gears
can't break if they are one big ball of weld. I have
yet to spin a front wheel with the rear welded--even
uphill around a corner on loose gravel while flooring it.
Too much traction!:grin:
Dual Ebrakes will allow you to transfer power to the
wheel that needs it. If your back is locked, it won't
slip even with a rear wheel in the air. If you have
dual Ebrakes, you'll be able to apply power to the
front wheel that needs it. Disclaimer: (because of
my traction I have never had to use the Ebrake system yet)
Glenn,
82 SubaruHummer--locked, Ebraked, tired--atv
84 GL Mad Max--still a virgin
01 Forester--yet another virgin
Thanks! Now I see the two options, either the sandrail hydraulic system, or a modification using two handles pulling on the parking brake cables individually. On my Forester, the parking brake is on the rear discs.
The sandrail one looks real promising, among other links I found this one, that explains it pretty well: http://www.geocities.com/Baja/Dunes/4099/turn.html
I'm a little concerned about the comment on breaking the differential. I suppose on the sand you'd be using them all the time, I just want it for the occassional time when I have diagonal tires spinning, and I'm wondering why I paid extra money to get the worthless rear VLSD!
