strat Posted March 17, 2006 Share Posted March 17, 2006 i have a question... do you guys disconnect the sway bars to get more flex out of the suspension? i know jeep guys use quick disconnects for ease of removal to get more flex but i'm not sure if you'd damage the axles/diff since most jeeps are solid axle. i'm wondering because i have an idea of quick disconnects and may fab something up but i want to make sure i won't do any damage to the drivetrain before i disconnect the bars and start flexing. thoughts? Link to comment Share on other sites More sharing options...
monstaru Posted March 17, 2006 Share Posted March 17, 2006 axles come and go.flex is there forever.........i don't even run swaybars.but then again noone said i had all my marbles either.fab some up. Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 17, 2006 Share Posted March 17, 2006 I've never had a problem in either of my offroad rigs, although i think that the EA-82 was happier on the road without it then the EA-81 was. Link to comment Share on other sites More sharing options...
ballitch Posted March 17, 2006 Share Posted March 17, 2006 i used a 20mm front sway at WCSS7...lol i dont if it would help, seeing as my sway bar endlinnk bushings are cracked and degraded like no other. so by the time all the bushings are smashed, the sway bar doesnt have much room to do anything in the way of transferring spring to the other wheel. ~Josh~ Link to comment Share on other sites More sharing options...
Numbchux Posted March 17, 2006 Share Posted March 17, 2006 I've got a very quick disconnect. it took me about 5 minutes to remove it completely. the subarus handle quite well without them, if you're wheeling hard enough that you think you should disconnect the sway bars, you shouldn't be driving hard enough onroad that you should need them. most of my jeep-driving buddies have removed them onroad. you just have to learn to take it down a notch. Link to comment Share on other sites More sharing options...
strat Posted March 17, 2006 Author Share Posted March 17, 2006 i don't want to remove the sway bars completely as i do want to be able to make an emergency lane change if need be and still be able to keep the car rubber side down... if there's no problems flexing without the bars, i think i'll have to get to work fabbing something up. Link to comment Share on other sites More sharing options...
MountainBiker Posted March 17, 2006 Share Posted March 17, 2006 i don't want to remove the sway bars completely as i do want to be able to make an emergency lane change if need be and still be able to keep the car rubber side down... if there's no problems flexing without the bars, i think i'll have to get to work fabbing something up. There should be no problem with the axles or anything else really. You might be able to get away with disconnecting just one side, assuming you have enough clearance for the bar to rotate up and down. I find that the lack of articulation stops me on some trails before I run out of ground clearance, so this is a great mod! Link to comment Share on other sites More sharing options...
erik litchy Posted March 18, 2006 Share Posted March 18, 2006 my jeeps was missing and i didnt even notice. soemwhere the end link bolt is laying in the road. i fixed it and its almost the same Link to comment Share on other sites More sharing options...
Numbchux Posted March 18, 2006 Share Posted March 18, 2006 the subaru suspension is very stable even without the sway bars. Even with a body lift, you can easily make an emergency lane change and not end up upside-down. Link to comment Share on other sites More sharing options...
scrap487 Posted March 18, 2006 Share Posted March 18, 2006 the subaru suspension is very stable even without the sway bars. Even with a body lift, you can easily make an emergency lane change and not end up upside-down. it sure is hard for me to land right side up when I have to swirve.... and I have my swaybar totally connected and tight... Link to comment Share on other sites More sharing options...
chazmataz Posted March 18, 2006 Share Posted March 18, 2006 when i lifted mine i totally disconnected my swaybar for flex and with 15" Buckshots on my wagon (EA82) it handled just fine and now with my 235/75-15 MT tires it handles better then before i lifted it. less understeer then when it was stock. i say just get rid of it, i'm thinking about taking mine completely off so it quits hitting my control arm. Link to comment Share on other sites More sharing options...
Numbchux Posted March 18, 2006 Share Posted March 18, 2006 it sure is hard for me to land right side up when I have to swirve.... and I have my swaybar totally connected and tight... hmmm.....something's not right there....maybe EA81's aren't as stable.... just noticed he's got a legacy.....that will be VERY stable without the sway bar. disconnect it from one side and take it for a test drive, I think you'll be pleasantly suprised. Link to comment Share on other sites More sharing options...
strat Posted March 24, 2006 Author Share Posted March 24, 2006 $8 solved the problem went to lowe's, picked up some 3/8" clevis pins and 4 pull style/hitch receiver cotter pins and bam... sway bar quick disconnects. easy to install, easy to remove, and the flex is awesome. Link to comment Share on other sites More sharing options...
operose Posted March 24, 2006 Share Posted March 24, 2006 pics of your ingenuity? Link to comment Share on other sites More sharing options...
strat Posted March 24, 2006 Author Share Posted March 24, 2006 pics of your ingenuity? i'll try to snap a few tomorrow Link to comment Share on other sites More sharing options...
MountainBiker Posted March 24, 2006 Share Posted March 24, 2006 i'll try to snap a few tomorrow Yeah, and show us how you supported the bars up out of the way while disconnected. Link to comment Share on other sites More sharing options...
strat Posted March 24, 2006 Author Share Posted March 24, 2006 the bars on mine hold themselves up no problem... i can even use two of the pins in the rear to hold the endlinks up on the sway bar going out to get some pics... Link to comment Share on other sites More sharing options...
Andyjo Posted March 25, 2006 Share Posted March 25, 2006 use bungy cords to keep it up out of the way Link to comment Share on other sites More sharing options...
erik litchy Posted March 26, 2006 Share Posted March 26, 2006 heres a pic of my broken one, all homeade. pics of your setup? http://www.ultimatesubaru.org/photos/showphoto.php?photo=10396&cat=500&ppuser=5108 Link to comment Share on other sites More sharing options...
