danbennett2u Posted March 17, 2006 Share Posted March 17, 2006 I cant seem to find this info, but what vehicles were available with LSD and how can you tell which ones have it? Thanks, Dan Quote Link to comment Share on other sites More sharing options...
edrach Posted March 17, 2006 Share Posted March 17, 2006 I cant seem to find this info, but what vehicles were available with LSD and how can you tell which ones have it? Thanks, Dan RX models, I think all years; optional on GL-10 turbo models (mostly '89). Some early model Legacies had a 3.900 VLSD. I don't know of any others. Label on diff is very clear: LSD 3.700. If the label is gone and the car is off the ground, turn the wheel; if the other wheel turns in the same direction it's either a LSD or welded diff; if it turns in the opposite direction it's an open diff. Quote Link to comment Share on other sites More sharing options...
Jibs Posted March 17, 2006 Share Posted March 17, 2006 I've seen a few on late 80's Full Time 4WD Turbo wagons and sedans. Quote Link to comment Share on other sites More sharing options...
CTC Posted March 17, 2006 Share Posted March 17, 2006 The info is in the FAQ sticky in the off-road forum: >>>> LSD Info! What year models? -late 80's Full time 4WD RX's -late 80's GL 10 Full time 4WD -Came as options on all ea82's -Full Time 4WD XT6's (Only 3.9 LSD) How do I tell If I have an LSD? -Look for this photo: (Thanks Dr RX!) It should be mounted on the rear diff. -Get your soob's rear end off the ground and spin a tire, if the opposite tire spins in the SAME direction, you have an LSD. Things to Know about the LSD -Almost all lsd's come in a 3.7 ratio, this needs to be converted to 3.9 on most soobs to be able to run. -Never run different tire sizes with an lsd. -The VLSD is not too good of an lsd for offroad use. How do I change my Lsd from 3.7 to 3.9? http://www.ultimatesubaru.org/forum/article.php?a=36 Questions about LSD swap and just general Qs? http://www.ultimatesubaru.org/forum/showthread.php?t=30872 >>>> Quote Link to comment Share on other sites More sharing options...
calebz Posted March 17, 2006 Share Posted March 17, 2006 Good post. Score one for the new guy! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 17, 2006 Share Posted March 17, 2006 no doubt, a newbie scouring for info. awesome! Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted March 17, 2006 Author Share Posted March 17, 2006 Awesome, thanks, I didnt think to look in off roading forum. Quote Link to comment Share on other sites More sharing options...
jeffast Posted March 17, 2006 Share Posted March 17, 2006 that is the best post on lsd i have ever seen Quote Link to comment Share on other sites More sharing options...
