TheSubaruJunkie Posted October 20, 2003 Share Posted October 20, 2003 I wanna convert my brat to Power Windows. Today at the junkyard I found a 2door GL10 Coupe, '83, EA81. I know the doors match, so would I just take the window and the power window guts from the GL10 doors and put them in the Brat? Will it all bolt up? Also, can I just hot-wire the switches and forget about all the wiring and the harness? I dont plan on using the center console with the switches, i will just have one switch on the passenger side door, and 2 switches on the drivers side door (one for each door). Anybody have any idea's for me? Or suggestions? -Brian Link to comment Share on other sites More sharing options...
mcbrat Posted October 20, 2003 Share Posted October 20, 2003 I suggest you send the innards to me you might need some of the wiring from under the drivers seat, as it has the relays, etc... needed for the auto stop function.... and auto up/down Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2003 Share Posted October 20, 2003 There's a power window control unit somewhere... not sure where, but just a heads up for you. I don't know what all it does, but probably works the auto up/down for the driver door I would imagine. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 20, 2003 Author Share Posted October 20, 2003 Hrm. Is all that stuff neccessary? -Brian Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2003 Share Posted October 20, 2003 I'm sure you could do without it, but if you are going to do it right, then yes, you at least need relay's to control the window motors - you don't want that much amp draw running through the switches. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 20, 2003 Author Share Posted October 20, 2003 Gotchya, ok... so i'll return on tuesday and get the stuff. Mick, if you want them bad enough, give me an offer and i might want to get them out of my garage that much faster -Brian Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted October 20, 2003 Share Posted October 20, 2003 Hey Brian, you don't even need the glass, as it will be different, jes make sure you get the innards that make it work, as for the switches, if you want door mounted ones, look for a 3dr with power windows, they had two switches on the the Dr door, and 1 switch on the Pas door. The wireing will work the same, you might have to swap out a connecter or two, but they are the same. I was going to do this with mine, and this is how I was going to do it. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 20, 2003 Author Share Posted October 20, 2003 So the power window glass is the same as the manual window glass? I think i could probably get the entire door for less than just the inners. -Brian Link to comment Share on other sites More sharing options...
mcbrat Posted October 20, 2003 Share Posted October 20, 2003 from the door, you just need the motor, regulator (geared thing) where it all attaches to the bottom of the glass. and the wiring to the door, and under the drivers seat. not sure if there's more.... the regular crank regulator bolts up to the glass the same way... if the doors are the same color as your brat, it would be easier to grab the door, and put the brat glass in it Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2003 Share Posted October 20, 2003 Get the whole door - easier, and you'll have an extra hatch, Brat, coupe door for that rainy day. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 20, 2003 Author Share Posted October 20, 2003 Doors are black/grey. Would look real goofy on my Silver brat Hopefully this is something i can pull off. I wanna do the power steering conversion as well. Thats alittle later tho. -Brian Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2003 Share Posted October 20, 2003 The power steering is easy - I'm going to do that on mine as well. I talked to Mudrat about it - he said it's basically plug and play, and since there's no electrical parts for the PS, it's REALLY easy. And as for the doors - keep em anyway - you never know when you might gert another Brat, and you could always paint them. Easy to paint a door cause it's already off the vehicle. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 20, 2003 Author Share Posted October 20, 2003 If I had a place to put them, I would... but right now my garage is getting kinda full. So i'll just grab the door guts. I do want the door panels tho. Its white on grey, just like Mt. Grizzley has. -Brian Link to comment Share on other sites More sharing options...
mcbrat Posted October 20, 2003 Share Posted October 20, 2003 no, white on gray like i WANT!!!!!!!!!!!! I've already got the ea81 GL-10 seats in my TB.... Link to comment Share on other sites More sharing options...
