heatwave Posted March 17, 2006 Share Posted March 17, 2006 i have an 87 brat that once i turn the ignition off it sputters and cutts up for about 15 seconds afterwards since im a rookie i have no idea how to fix this im sure its just some minor adj needed but i have no idea what to do or where to start Link to comment Share on other sites More sharing options...
82Brat Posted March 17, 2006 Share Posted March 17, 2006 Check ignition timing...should be 8 deg BTC. Also make sure all the mounting bolts on the carby are tight. Finally, could be a faulty anti-dieseling selonoid but I've only read about that and have no clue how to troubleshoot. I've gone to the Weber carb so I don't have one of those any more. Link to comment Share on other sites More sharing options...
suburpy Posted March 17, 2006 Share Posted March 17, 2006 Yup, this is called diesling - could be a number of things, check that ignition timing is set correctly and that idle speed is correct. If this doesnt stop it could be the anti-diesling solenoid on the carby, get one from JY and see if that changes it. Mostly I find this has occured due to timing. Link to comment Share on other sites More sharing options...
