desperate Posted March 18, 2006 Share Posted March 18, 2006 I found the other day my gas tank has a leak. closer inspection it has several little pin holes that have rusted through, I tried to use jb weld after properly preppin the surface, and it still leaks like a ***************. I found several new tank, but they are 250+. Thought I'd consult the forums and see if any one knew of a place with better prices. Anthony EDIT: its a 91 loyale 5spd, front wheel drive 1.8L motor Link to comment Share on other sites More sharing options...
Subieguy Posted March 18, 2006 Share Posted March 18, 2006 Gas tank for what? That would help us out a little. Link to comment Share on other sites More sharing options...
desperate Posted March 19, 2006 Author Share Posted March 19, 2006 Gas tank for what? That would help us out a little. sorry bout that, was in a hurry. problem fixed Link to comment Share on other sites More sharing options...
Gl-boost Posted March 19, 2006 Share Posted March 19, 2006 Wow this is crazy I was just going o post the same thread. I have an 87 Gl-10 4WD and I just fixed two gas lines under the rear seat on the drivers side. I was drive ing the car today on a 60 mile round trip and smelt gas when I opend the window or sunroof. I saw no dripping anymore like before. Well when the car was at my dads garagee I noticed that the tank also leaked. This sucks royaly. It appears to be the seam of the tank right by the filler neck but I think its lust the filler neck hose leak. But there is also two little lines in the side of the gas tank by the filler neck and this is what appears to be leaking which appears to be going over the seam. Are these common leaks. I am worried though that if I mess with it the line will break of. Hopefully its just the clamps and not the metal line that the hose attaches to so can anyone help us. I also don't mean to high jack your thread. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 19, 2006 Share Posted March 19, 2006 Out here the yards remove the tank and put it in the back seat or trunk so they are availible from the junk yards here.... not sure about where you live. Shipping wouldn't be all that bad, but have to clean it up good and cover sharp edges with cardboard ect - still it certainly wouldn't be $250. Have you tried any radiator/gas tank shops? They could probably patch it as well. Also try the wanted forum here on our board - perhaps someone is parting a car in your area. As for this being common - it's a rust-effect from your salt. Out here I've never seen any subaru fuel tank leak no matter how old. GD Link to comment Share on other sites More sharing options...
Durania Posted March 19, 2006 Share Posted March 19, 2006 Well you could to it like the race cars and put like a 5 gallon tank in your trunk. Just an idea. Link to comment Share on other sites More sharing options...
Gl-boost Posted March 19, 2006 Share Posted March 19, 2006 Well I was going o hit the local junk yards tommorow. I am monitoring the leak as of right now and makeing sure it is the lines. the only thing is that when I try o clean up the area I dont want to break them off. Link to comment Share on other sites More sharing options...
86subaru Posted March 19, 2006 Share Posted March 19, 2006 i have 86 4wd wagon with one on it , sitting in my garage , but not sure how it comes out, also the wagon was pretty rusty , so i stripped it ,and it's ready for the junk man , if it would come out easy i will sell it to you cheap + shipping Link to comment Share on other sites More sharing options...
Quidam Posted March 19, 2006 Share Posted March 19, 2006 Well I was going o hit the local junk yards tommorow. I am monitoring the leak as of right now and makeing sure it is the lines. the only thing is that when I try o clean up the area I dont want to break them off. Hey boost, Look into your right rear fenderwell. The coverplate for the fuel filler neck and lines is in there. Pull the plate off, i think it's three bolts that holds it on. The bolts may break even if you spray them down with penetrating oil. I replaced one filler neck because it had a hole in it where the mounting bracket is located. Taking that plate off will allow you evaluate this area and clean it out. There is usually a lot of crud up in there. Hope this helps. Link to comment Share on other sites More sharing options...
Gl-boost Posted March 19, 2006 Share Posted March 19, 2006 Ok will do, I already cleaned out as much as possible. Its just hard to find time to do this as I am always on the go. I also checked the seam at the back of the tank. It looks as if its leakeing from here somewhere or just from the side and them spreading. Its hard to tell because the gas spreads everywhere. Link to comment Share on other sites More sharing options...
stumpy Posted March 19, 2006 Share Posted March 19, 2006 I also have a tank for an 86GL 4WD in nice shape and already pulled. We don't have the rust problem here unles you live down on the coast. Open to offers if any one decides to go that route. Stumpy Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 19, 2006 Share Posted March 19, 2006 There are shops that can take your tank and refurb it - they pour in a lining to seal it up. If it's not too bad it may be cheaper and easier to go that route. Otherwise there are plenty of people with old ru's out here that have no rust. Tanks out here are as good as new for the most part. GD Link to comment Share on other sites More sharing options...
Gl-boost Posted March 20, 2006 Share Posted March 20, 2006 Well I thank you guys for the ofers but will see if the local junkyards have a good one first, but I will remember if I need a gas tank to talk to you guys about one. I will also look into it more before I get one. Link to comment Share on other sites More sharing options...
desperate Posted March 20, 2006 Author Share Posted March 20, 2006 86 Subaru and Stumpy, how much you want for your tank? I'm goin to call the junkyard tomorrow, but i doubt they will have one in decent shape. Link to comment Share on other sites More sharing options...
Turbone Posted March 20, 2006 Share Posted March 20, 2006 If you use a 4wd tank, you will lose a couple gallons. I dont recall the exact sizes, but the tanks are different. Link to comment Share on other sites More sharing options...
stumpy Posted March 21, 2006 Share Posted March 21, 2006 Will a tank form a wagon fit into a sedan? 86GL wagon into 91 loyale sedan? Thanks for any help in clearing up this issue. Stumpy Link to comment Share on other sites More sharing options...
desperate Posted March 22, 2006 Author Share Posted March 22, 2006 /\ +1 Link to comment Share on other sites More sharing options...
