hey
97 obw 2.5 182000miles
just replaced heads due to failure of pulley.
put new pulleys on and new timing belt.
on cold mornings i am hearing a claterring/knocking coming from the front of the engine. as soon as the car warms up it goes away as far as i can tell. i have heard that a failing tensionr can cause the belt to loosen and slap on the cover until the heat makes the fluid work better. does anyone know anything on this.
or know a way i can check to see if the tensioner is failing.
i never want to experience bent valves again- complete nightmere
i know about piston slap but have never heard it to compare the sounds.
please help
pull the old style tensioner and mounting block off a old 2.2 89-95 and put it in yours. It bolts right up and then you don't have to worry about the new one failing.
Could the "old style" tensioner be found also on the 96 2.2liters engine? Mine is a cylinder and piston style tensioner mounted horizontaly and pushing on a pulley from right to left (standing in front of the engine). Just to know if I have the bullet proof kind or not.
