Subaru winch
  Jack in Norfolk said:
Does anybody have a working Subaru winch? Just curious. I know they made them; I've just never seen one.
I believe moosens 78 4WD wagon has a factory Subaru winch on it...dont hold my word to it though.
THe one that came with my car,before I took possession of it,was yellow.I think it's a Warn(?),maybe a Reese...but that one never made it to me.The previous owner traded it just before I got the car.
So,EZap sent an orangeish-red one to me.It bolts right up,so maybe it's the same,not sure.
Mine is not funtional at this time,but the wiring is still there from the original install.
Kids point at it all the time.People like seeing my '78 but then they see the winch it totally tickles them.:)
they came in yellow (most common), and white...
here's a brochure page with the yellow one...
http://www.ultimatesubaru.org/Literature/brochures/1980-acc-a.jpg
and here's a white one...
http://www.ultimatesubaru.org/Literature/brochures/1982-brat-h.jpg
they were just a small Superwinch. 1000 pounds... I think
I have a working yellow one, and Syrinx has a yellow on, New in The Box!!!!!
Is there anything wrong with getting a winch designed for an ATV instead? They are smaller but with big capacity. Like Warn's 4.0i Utility Winch 4000 lbs capacity single line at 12V DC. http://www.warn.com/atv/winches/40ci_winch.shtml The weight of the unit is 21 lbs. Quite light IMHO. It should be able to pull the lightweight Scoobie out of many situations. As always have a good battery to use a winch. It is not OEM but should do quite well, right?
just remember....if you get a winch I highly recommend getting one of those thingys (can't remember the right name) that has a pulley at the end and you put the lead through it and bring it back to hook onto the car. (is snatch block right????) I believe they double the capicity of the winch when you have one of those. Something like that (don't mind me...was just at the Dr. and can't think right)
