drive in deep water
ahlman
how to make the waterclearence higer, to protect the ignitionsystem??
how big tires is it possible to have without losing to much power and get to high speed?
my car is a subaru brat -86
I am sorry for my bad English, I am from Sweden:grin:
Din Englisk ar inte nar dalig nar mitt svenska!!!
Bulid yourself a snorkle.. all you need is some pvc... pvc cement, silicon stuff... it's a good time.. a heat gun will help alot if you want to bend the pvc.
Other than that, seal up the disty real good, and have a good time :headbang:
lol, just try the seach, run some 25ish inch tires, find some 14inch pugs or something like that. I've heard to wrap a cloth around the disty, depends how long ur going in the water, if its just a quick crossing, that should help. ask Zap. probably some of the best things u could do is get a lift and bigger tires, around 28's or something. you will litterally float. :banana: I'd advise mounting a outboard on the back somehow :lol: j/k
my impreza (with snorkel) DID float....
with some more mods.. I am going to see about making it float for a longer duration :D
as for the electronics and carb stuff in a brat, it is a bit complicated to seal up... disty, carb intake and coil... not too much to worry about!
