creativefilmcars Posted March 20, 2006 Share Posted March 20, 2006 We have a 1994 4x4 Loyale wagon with 165/80R13 on it. Does anyone know if 185/70R70 would have a problem fitting? They have approximately the same rolling circumference. (http://www.powerdog.com/tiresize.cgi) It is the width I am worried about. For some reason the 4x4 have taller, narrower tires. Any one know the reason? Link to comment Share on other sites More sharing options...
RONAN Posted March 20, 2006 Share Posted March 20, 2006 Yes, you can run 185/70R/13`s without a problem. I have them on my 93 Loyale wgn right now... Link to comment Share on other sites More sharing options...
creativefilmcars Posted March 20, 2006 Author Share Posted March 20, 2006 Thanks Link to comment Share on other sites More sharing options...
soobmater Posted March 20, 2006 Share Posted March 20, 2006 thats what came on mine, i think it should be the stock size.... Link to comment Share on other sites More sharing options...
ballitch Posted March 20, 2006 Share Posted March 20, 2006 185/70/R13 is the stock size.....those 165's must be pretty squirrely....way too thin. ~Josh~ Link to comment Share on other sites More sharing options...
robm Posted March 21, 2006 Share Posted March 21, 2006 165SR13 was the stock size on the wagons. It was replaced by 165/80 R 13. This tire size is getting very hard to find in Canada. Most manufacturers do not make them. 185/70 is also getting hard to find. 175/70 is commoner, but it looks rinky dink in the wheel well, as it is 1" smaller in diameter, which also upsets the speedometer noticeably. This sucks. It may be an idea to get some 14" Peugeot wheels, just to get a decent selection of tires, but 14" tires cost more. (I am a real cheap bustard, you bet!) 4x4's run high aspect ratio tires to keep the wheels away from rocks etc. on the road. High aspect ratio tires also have a better load rating than low, so a tall narrow (cheap) tire can carry more than a low wide (more expensive) one. This is probably why tall narrow tires are found on 4x4's: cost and ground clearance. Link to comment Share on other sites More sharing options...
Tom63050 Posted March 21, 2006 Share Posted March 21, 2006 165SR13 was the stock size on the wagons. It was replaced by 165/80 R 13. This tire size is getting very hard to find in Canada. Most manufacturers do not make them. 185/70 is also getting hard to find. 175/70 is commoner, but it looks rinky dink in the wheel well, as it is 1" smaller in diameter, which also upsets the speedometer noticeably. This sucks. It may be an idea to get some 14" Peugeot wheels, just to get a decent selection of tires, but 14" tires cost more. (I am a real cheap bustard, you bet!) 4x4's run high aspect ratio tires to keep the wheels away from rocks etc. on the road. High aspect ratio tires also have a better load rating than low, so a tall narrow (cheap) tire can carry more than a low wide (more expensive) one. This is probably why tall narrow tires are found on 4x4's: cost and ground clearance. Kumho (www.kumhousa.com) makes a nice and inexpensive tire, called the Touring A/S I think, in 185/80x13. Might want to check it out. That's what I'm putting on my newly-purchased 13" alloys. I think that tire also comes in 185/70x13. Link to comment Share on other sites More sharing options...
Crawlerdan Posted March 21, 2006 Share Posted March 21, 2006 Kumho (www.kumhousa.com) makes a nice and inexpensive tire, called the Touring A/S I think, in 185/80x13. Might want to check it out. That's what I'm putting on my newly-purchased 13" alloys. I think that tire also comes in 185/70x13.i got 215 60 15s on my gl with no rub or trimming, youll be fine with those:headbang: Link to comment Share on other sites More sharing options...
robm Posted March 21, 2006 Share Posted March 21, 2006 Problem is, 185/80 won't fit in the spare tire holder. And it is way taller, so the speedo is way out. A good bet for minor offroading, as it improves ground clearance. Not the greatest for what I want, which is the cheapest highway vehicle I can get, with decent logging road capability for the odd weekend. I will have a look for the Kumhos. They seem to make a pretty decent tire. The 185/70 Hankooks I have on are just about shot, at less than 20,000 miles! Link to comment Share on other sites More sharing options...
MilesFox Posted March 21, 2006 Share Posted March 21, 2006 i generally see 185/70 and 175/70 as stock sizes on older soobs,especially 4wd as far as the tire is concerned, it will fit on the rim no problem and be proper for the car. just be sure all of your tires are the same size!! a 185/70 will fit under the hood Link to comment Share on other sites More sharing options...
goatcheez Posted March 21, 2006 Share Posted March 21, 2006 Yep that's the size they just put on mine yesterday!! goatcheez Link to comment Share on other sites More sharing options...
creativefilmcars Posted March 21, 2006 Author Share Posted March 21, 2006 Thanks for all the feedback. A set of 185/70SR-13 Kumho Touring A/S 795 are on there way from Tire Rack. Can't sneeze at $34 each! I let you know how they perform in New York potholes! Link to comment Share on other sites More sharing options...
soobmater Posted March 22, 2006 Share Posted March 22, 2006 Problem is, 185/80 won't fit in the spare tire holder. And it is way taller, so the speedo is way out. A good bet for minor offroading, as it improves ground clearance. Not the greatest for what I want, which is the cheapest highway vehicle I can get, with decent logging road capability for the odd weekend. I will have a look for the Kumhos. They seem to make a pretty decent tire. The 185/70 Hankooks I have on are just about shot, at less than 20,000 miles! not to poop on you're popsicle, but this is creativefilmcar's question. the speedo isnt going to be that far off. only like a couple miles per hour. IE when you're speedo reads 50, you are really going 53.2. My car came stock with 185/70/13. thats what it says on the door cill, in my owners manual, and in my chiltons. my advice, go for the 185/70/13's, they will fit for shure no worrys at all. (and about the spare tire spot, thats what a roof rack is for ) Link to comment Share on other sites More sharing options...
creativefilmcars Posted March 27, 2006 Author Share Posted March 27, 2006 Had the tires fitted and they are great! What a improvement. Highly recommend anyone still running the stock 165/80R13 to switch post haste! Better handling and no real change in the speedo. Perfect. I'll let you know how the Kumho's are in the long run. Link to comment Share on other sites More sharing options...
romcat Posted December 12, 2006 Share Posted December 12, 2006 i got 215 60 15s on my gl with no rub or trimming, youll be fine with those:headbang: Hey: what are the tire make and model and what rims are they mounted on? Thanks, Romcat Link to comment Share on other sites More sharing options...
Petersubaru Posted December 12, 2006 Share Posted December 12, 2006 I am useing 185/80/13 on my '86 4x4 with plenty of clearance to spare... We have a 1994 4x4 Loyale wagon with 165/80R13 on it. Does anyone know if 185/70R70 would have a problem fitting? They have approximately the same rolling circumference. (http://www.powerdog.com/tiresize.cgi) It is the width I am worried about. For some reason the 4x4 have taller, narrower tires. Any one know the reason? Link to comment Share on other sites More sharing options...
jacobs Posted December 12, 2006 Share Posted December 12, 2006 Problem is, 185/80 won't fit in the spare tire holder. And it is way taller, so the speedo is way out. A good bet for minor offroading, as it improves ground clearance. Not the greatest for what I want, which is the cheapest highway vehicle I can get, with decent logging road capability for the odd weekend. Those of us that do offroading in the snow, we must remember we need extra wheel well clearance for tire chains. Link to comment Share on other sites More sharing options...
jacobs Posted December 12, 2006 Share Posted December 12, 2006 I don't mean to hyjack the thread but does anyone know what the smallest 15" tire that's available? Link to comment Share on other sites More sharing options...
