subiemech85 Posted March 21, 2006 Share Posted March 21, 2006 this time with INDUSTRIAL ENAMEL the rust keeps spreading, stripes were rust-oleum, paint looks kinda crappy, cracking will probably keep the color scheme with gloss white body, aluminum for the gray bits, and MF red for the stripes, and a gloss black hood current paint http://www.ultimatesubaru.org/forum/showthread.php?t=44427 paint supplier http://vansicklepaint.com/mntvsinden.html about $20 a gallon at the farm store any idea how much paint would be needed? coverage is approximately 400-450 sq. ft. per gallon Link to comment Share on other sites More sharing options...
ple1ades Posted March 21, 2006 Share Posted March 21, 2006 So are you selling the CF hood? Link to comment Share on other sites More sharing options...
mikeshoup Posted March 21, 2006 Share Posted March 21, 2006 So are you selling the CF hood? Holy crap, this was in another thread. Its not a CF hood, its a CF hood scoop. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 21, 2006 Share Posted March 21, 2006 I like that paint you have, sucks about the rust. Im spoiled living in California... not a spec of rust on it. Where did you get that scoop? -Brian Link to comment Share on other sites More sharing options...
Gl-boost Posted March 21, 2006 Share Posted March 21, 2006 I was thinking about painting my Gl-10 also. with normal size cars a galon should do. It only gets bad when you screw up or want alot of coats then you could run out. I think a normal base coat repaint is three coats of paint. I also have rust and I was going to probly por15 my under side but I don't know yet. I have rust by the back rear sub mounts ( I think thats what they are called, the rear end bolts up here) and was going to weld in metal and cover this up. Link to comment Share on other sites More sharing options...
rllywgn Posted March 21, 2006 Share Posted March 21, 2006 2 stage paint, 2 qts color and 2 qts reducer will yield a gollon of sprayable color should be able to cover the car, door jams, and trunk area. unless your going for some heavy coating, single stage paint, you should just need a gallon of this, no clear coat required medium gloss finish unless you really go all out color sanding. im doing the rattle can spray job on mine... (my are hurts from color sanding) and some of those rust converters seem to do well... i only had a few spots though.. rllywgn Link to comment Share on other sites More sharing options...
moshem74 Posted March 21, 2006 Share Posted March 21, 2006 o.k. this is the nice'st coupe that you ever saw...paint it in this color , the best : Link to comment Share on other sites More sharing options...
