yodannyc Posted March 23, 2006 Share Posted March 23, 2006 arghhhh! ok now that i got some of my frustration out. heres my story if you dont know it already. 87' subaru carbed ea 82 Blew up my motor. So i got some help from General Disorder. He hooked me up with a free fuel injected ea 82 block that came from a wrecked soobie. carb system bolted right up so the fact that it is a fuel injected motor does not even really matter. Ok so i am now done connecting everything. i go to start it up and it doesnt even crank! so i am thinkin dead battery or starter. cause electrical is not an issue on these carbed ea82 systems. So i go to jump start it with my truck and nothin! and when i went to jump start i wanted to see if it would arch by tapping the two ends of the cables together and there wasnt a arch. so dead battery right? but my dash and inside lights work. and the battery volt indicater says 12amps. So may be its my starter? I know that when my motor blew up it happned in the middle of me trying to start it. So being stupid i kept on cranking on the ignition. so i think i might have burned out my starter... not sure though. What do you guys think? please help. and if its my starter does anyone have a general price for these? I really wanted to start my car today but no luck. may be next time. thanks p.s. what happned to you general disorder? I need your help man. Link to comment Share on other sites More sharing options...
Indrid cold Posted March 23, 2006 Share Posted March 23, 2006 Manual tranny? Push it. Yea.. possibly starter, crossed leads? Battery in wrong? Blown main fuse? Hmmm... I am still learning here but just some thoughts. If manual tranny does it roll smoothly when in neutral.. ie not bound at clutch plate and flywheel? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 23, 2006 Share Posted March 23, 2006 Umm - did you connect the little black wire to the starter solenoid? There are two wires to the starter - one BIG red wire, and a little solenoid wire that goes to the spade terminal on the top of the starter. As to what happened to me - came home to a busted pipe in the ceiling above my toilet - had to rip out half the drywall to get to it, and then make two trips to home depot, etc, etc. I'm just now mopping up. I saw you called, but I've been knee deep in soaked rags, and plumbing parts all night. GD Link to comment Share on other sites More sharing options...
calebz Posted March 23, 2006 Share Posted March 23, 2006 Jeez Rick, Excuses, excuses;) Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 24, 2006 Share Posted March 24, 2006 Check the Starter... Maybe it`s incorrect mounted... Link to comment Share on other sites More sharing options...
