fastenova Posted March 23, 2006 Share Posted March 23, 2006 Got an ea81 motor, ea82 intake manifold w/ weber 32/36 DFEV. Choke is disconnected right now. Starts up, runs great for ~5 minutes, lopes, and dies. I run the starter for a few seconds, let off, give the acc. a couple of pumps and she fires right back up and runs for another 5 minutes. Playing with the throttle doesn't help, I revved it up a little and she just dies a little faster. Am I running rich? Lean? I am new to carbs... Help! Thanks! PS - Thanks to all on the board for the help in the past, and all the great info that's on here =) Link to comment Share on other sites More sharing options...
86ruguy Posted March 23, 2006 Share Posted March 23, 2006 Sounds Like You're Runnin Out Of Fuel To The Carb Link to comment Share on other sites More sharing options...
fastenova Posted March 23, 2006 Author Share Posted March 23, 2006 Looking at my fuel filter it's staying plenty full. What else can I look for? Thanks! Link to comment Share on other sites More sharing options...
erik litchy Posted March 23, 2006 Share Posted March 23, 2006 sounds like a choke problem possibly Link to comment Share on other sites More sharing options...
Phizinza Posted March 24, 2006 Share Posted March 24, 2006 fastenova said: Choke is disconnected right now. But is the choke butterfly open or closed? The choke may be stuck on. Is it manual or auto choke? Link to comment Share on other sites More sharing options...
fastenova Posted March 24, 2006 Author Share Posted March 24, 2006 Choke is open completely. It's an auto choke, having issues with that too but I want to get the darn thing running before I tackle that. I just replaced the power valve (needed to do it anyway and I just got it) and bought a set of calipers so I could accurately set the float. I just got done setting the float and it stalled again. So tore open the carb again, cleaned out the little screen in the fuel inlet, it wasn't visibly dirty or clogged. The level of fuel was down again though. The float level is set accurately. So next is replacing the filter at the fuel tank and possibly dropping the fuel tank to clean it out. Any thoughts? Link to comment Share on other sites More sharing options...
erik litchy Posted March 24, 2006 Share Posted March 24, 2006 fastenova said: Choke is open completely. It's an auto choke, having issues with that too but I want to get the darn thing running before I tackle that. I just replaced the power valve (needed to do it anyway and I just got it) and bought a set of calipers so I could accurately set the float. I just got done setting the float and it stalled again. So tore open the carb again, cleaned out the little screen in the fuel inlet, it wasn't visibly dirty or clogged. The level of fuel was down again though. The float level is set accurately. So next is replacing the filter at the fuel tank and possibly dropping the fuel tank to clean it out. Any thoughts? i think you would be wasting your time with the fuel tank. how warm does it get after 5 min? id install a fuel pressure guage next Link to comment Share on other sites More sharing options...
fastenova Posted March 24, 2006 Author Share Posted March 24, 2006 Wahoo! Installed a close-enough Deutsch fuel filter and she's running beautifully now! I am going to take her for her FIRST drive around the block since I've owned her!!! Thanks to everyone! -Aaron Link to comment Share on other sites More sharing options...
fastenova Posted March 24, 2006 Author Share Posted March 24, 2006 OK, so first drive went alright, she had a LOT of power. And was really noisy. It seems like there's some issues with the clutch, but I haven't even looked at that portion of the car yet Might just need adjusted, or something. I also think there might be an issue with the catalytic converter, but I'll bang on that tomorrow and see if I can figure out what's up. Next on the list is a thorough brake and suspension check and then baby's gettin' a new set of shoes! USMB ROCKS! Aaron Link to comment Share on other sites More sharing options...
