seth3030 Posted March 24, 2006 Share Posted March 24, 2006 i just found that where my cable attaches to my pedal right by there there is a retaining clamp, on a metal peice the metal peice is ripped and i don't know what to do so if anyone could help that would be great. Link to comment Share on other sites More sharing options...
Durania Posted March 24, 2006 Share Posted March 24, 2006 i just found that where my cable attaches to my pedal right by there there is a retaining clamp, on a metal peice the metal peice is ripped and i don't know what to do so if anyone could help that would be great. Mine broke off about the same way yours did. I just simply bought a new clutch cable and that fixed it for me cause it came with something that replaced that part. It helped my problem but my hatch still needs a clutch like a mother. Link to comment Share on other sites More sharing options...
idosubaru Posted March 24, 2006 Share Posted March 24, 2006 so the entire clutch cable is good it looks like based on your drawing? anyway to post a digital picture of it? if it's cable related, buy a new cable. if it's the arm that the pedal connects too then that is strange. has it failed yet or is it still useable? weld it. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 24, 2006 Share Posted March 24, 2006 Also, you may need to take off the entire pedal to take it off, and maybe you can weld it, but I think that piece came along with a new cable, you can try to change it with a new one. To change the entire cable you need to take the pedal off. Maybe you can post here a Photo of this. Your Drawin` is Good, but a Photo maybe can help too. Good Luck! Link to comment Share on other sites More sharing options...
Durania Posted March 24, 2006 Share Posted March 24, 2006 I would just simply go with a new clutch cable. You have to crawl underneath your dash to where your clutch pedal is, pull out a little pin that holds the cable to the pedal, then unbolt it from the clutch fork underneath the hood. DO NOT DO THIS IN A HURRY! I made that same mistake and it took me forever to get everything back in order, a new cable is also a pain in the butt to snake through the firewall to the fork because its so stiff. Link to comment Share on other sites More sharing options...
idosubaru Posted March 24, 2006 Share Posted March 24, 2006 be sure to look at or take a picture of the cable set-up on the pedal, i recall installing mine incorrectly first time i did it. had to take it off and do it again. Link to comment Share on other sites More sharing options...
