EA82 Radio Questions
Also Remember This, is Important:
Subaru did make in the 80`s and part of the 90`s the Radio connections, using a common ground between the front and the rear speakers of the same side, but the positives are all independent.
Due to the extremly delicate circuits of the newer radios, if you do not put in a new cable for the ground of the back speakers (As I Did, or for the Front ones, do what you preffer) you will damage the unit for sure.
So, prior to install a new radio, be Sure that all the speakers are fully independent...
Good Luck! :)
SyntheticBlinkerFluid, Yes, there is a fit/installation kit for EA82. I have a wagon and it required spacing it out 1" from the dash to fit a standard DIN radio. The hatchback's, if I recall correctly, required a panel replacement.
I believe I have extra parts for the fit/installation kit which I will never use. It came with all the parts needed for almost all years and multiple models of older Subarus. IM me your address and I will give you the parts and I just want you to send me the postage for USPS Priority.
Please cite what relevant information is needed (make, model, year) and I will look at the kit. Then send you pictures.
do you know where you got the kit? I would be interested in purchasing one of my own. I'm running into the same problem of not having enough depth to put my radio all the way back where it "should" be.
...I'm running into the same problem of not having enough depth to put my radio all the way back where it "should" be.
Well... I fix it by doing a Wood "Adapter", it covers all the open space of the Radio Area, and it`s about 2" Thick, to give the Extra Space... It`s attached with Screws.
SynBlinFlu
Loyale 2.7 is correct about the common wire for the
front and rear speakers
(it is not grounded as some will tell you)
But there is a simple way to by pass this with out running new wires.
Please read this entire post, I made an error and was corrected,
it can be done behind the dash at the connector.
radio wiring without common connections
I purchased my kit from the local Car Toys. I do have the Metra 99-8900 kit.
I used the faceplate for my 88 Wagon. The faceplate I used is for the EA82 cars (faceplate #1). The faceplate for the EA81 is available (Faceplate #2 includes the 82-87 Brat, 81-84 DL and 81-84 GL). Finally the faceplate for the Justy is available (Faceplate #4 w/mounting brackets) The faceplate #s are found in the instruction manual: http://www.metraonline.com/downloads/pdf/TurboKits/INST99-8900.pdf
Anyone want Faceplate #2 or #4? $5 for each faceplate set (money is for shipping) will get them. USPS Priority. USA only.
