ausubaru92 Posted March 24, 2006 Share Posted March 24, 2006 I was thinking of putting 15" wheels on my car I was thinking something like this..... but with low profile tyres to match the rolling diameter of the stock 185/75r13,... i like being different:cool: What are the advantages of larger rims, also, disadvantages too. Past experience, problems, anything,.... i wanna know it all:slobber: Cheers Quote Link to comment Share on other sites More sharing options...
subyrally Posted March 24, 2006 Share Posted March 24, 2006 i have a set of 15" pugs on my rx, they are great, granted they dont tuck under the front fenders. the handling is great with them cause i have performance tires on em. Quote Link to comment Share on other sites More sharing options...
86ruguy Posted March 24, 2006 Share Posted March 24, 2006 i also have 15in pugs on my 86 ea82, and even though i will be lifting it eventually, the handling is much better with the wider tire. 195/60/r15's Quote Link to comment Share on other sites More sharing options...
soobscript Posted March 24, 2006 Share Posted March 24, 2006 If your rims are wider than stock, 205/50-15's work well. [plug] I actually have a set of Michelin Pilot super summer tires mounted on 15" Allied Armament 4-lug wheels for sale in the classifieds section... LINK [/plug] --Ed Quote Link to comment Share on other sites More sharing options...
A DOG Posted March 24, 2006 Share Posted March 24, 2006 I rock 15in wheels on my lifted wagon. Theres more tire selection with 14in and 15in rims. A wider stance, and better handling. Plus subies look cool with bigger rims than stock 13s. Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted March 24, 2006 Share Posted March 24, 2006 just somethig to watch on those stamped steel type wheel is they can have trouble balancing them properly, which especially with lower profile tyres can give you some issues Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted March 24, 2006 Author Share Posted March 24, 2006 So pros are obviously better looks, tyre selection and handling. What are the cons, i assume that i wont be able to travel on really rough terrain (but i drive on road 95% of the time) subyrally.. what do you mean they dont tuck under the renders, are they 15x6 or are they bigger? what size rubber do you have, i was told that 195/55r15 would give same rolling diameter as my 13's Any other points i should consider? Quote Link to comment Share on other sites More sharing options...
calebz Posted March 25, 2006 Share Posted March 25, 2006 Offset will make a difference. Is this an offroad type thing or street thing?. I am currently running 02 WRX wheels 16x6.5 I believe, with 205/50/16s (might be 55) The car is lowered a bit below stock. Not slammed by any means. THey tuck up in the rear quite nicely, and with a little bit of front fender rolling, they will tuck in front. When I had 14 inch pugs though, no tuck.. WRX wheels = 53mm offset Pug wheels = 20mm offset IIRC Most aftermarket 40mm Some aftermarket = 48mm Subarus have a weird offset, a few mm can be the difference between rubbing and no rubbing. Quote Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted March 25, 2006 Share Posted March 25, 2006 The PUG wheels have a lower offset than stock thus they stick out further..I like mine lol 205/50ZR15 kumho ecstaMX on the front and 205/50r15 kumho ecsta 712 on the back.. Quote Link to comment Share on other sites More sharing options...
rallyruss Posted March 25, 2006 Share Posted March 25, 2006 15" alloy pugs. 205 50 15 Khumo asx. speedo is dead on. handling is way better than stock. a nice fit. only down sides are increased cost of tire replacement and the wider tires tend to wander a little on our crappy california roads. Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted March 27, 2006 Author Share Posted March 27, 2006 I talked to a tyre dealer and he told me that the correct size would be 185/50r15, or 195/50r15 but it would put more strain on my driveshafts:confused: Do 195/60r15 work without rubbing the fenders with standard suspension and how does it affect the speedo? The guy actully recomended 14" wheels cos of how 185/50r15 profile tyres act on rough roads and gravel. I have a gravel driveway thats about 200mts long. What would you recomend??? Cheers Quote Link to comment Share on other sites More sharing options...
Jibs Posted March 27, 2006 Share Posted March 27, 2006 Here's a pic of my 82 Brat with 195-60-15's (I believe its that size, may be real close) mounted on 15x7 6 lug rims. I DO have a 4" lift, so I can't tell ya how they fit without. Looked way goofy though. Quote Link to comment Share on other sites More sharing options...
subyrally Posted March 27, 2006 Share Posted March 27, 2006 my handles great on gravel roads, even with 205/50/15 tires on it. but then again, its not a mushy luxury car either. i honestly prefer to have a stiffer ride, not quite as bad as a track car, but i dont like a mushy ride. and if your suspension is working properly, it shouldnt be too bad with 15" low profile tires. I talked to a tyre dealer and he told me that the correct size would be 185/50r15, or 195/50r15 but it would put more strain on my driveshafts:confused: Do 195/60r15 work without rubbing the fenders with standard suspension and how does it affect the speedo? The guy actully recomended 14" wheels cos of how 185/50r15 profile tyres act on rough roads and gravel. I have a gravel driveway thats about 200mts long. What would you recomend??? Cheers Quote Link to comment Share on other sites More sharing options...
ausubaru92 Posted March 28, 2006 Author Share Posted March 28, 2006 OK, now the big question,... your opinions on if it will look good? 15 White steel rims with low profile rubber on a Metallic red L wagon? I like the idea of 15" but i wonder how they will go on some of our rough roads. I live in a rural area and some of our roads have lots of potholes. Would i just be better off with 14" Im gonna fire up a photo editor and do a photochop and see if i like it. Thanks for all the advice and keep it coming. Quote Link to comment Share on other sites More sharing options...
eddygordouk Posted March 28, 2006 Share Posted March 28, 2006 kinda thread jack but I too was wondering what would be best for a wheel size choice, especially if I were to lower a bit past stock. would 15" or 14" be best? it feels like 15 seems still a little too big for a lowered sub... Quote Link to comment Share on other sites More sharing options...
