Oil Leak
is it possible for pictures? the best way to figure out where its coming from is to clean the engine as best you can(spotless if possible :lol: ). some DIY carwashes have pressure washers you can use that spray a water and a degreaser. I use foamy engine brite in the aerosol cans most of the time but the easiest way is take it to a car wash, if you do that make SURE you cover up the air intake, and cover/seal the distributor(unless you wanna wait for it to dry out :rolleyes: )
there is no excess of oil just a little black that comes off on my finger so i dont think its near the main pulley on the timing belt so any other clues
welcome to the world of old school subarus the only time i worry is when mine isn't leaking oil just make sure not to run it dry on the other hand if you find it it shouldn't be hard to fix
