pearlm30 Posted March 26, 2006 Share Posted March 26, 2006 What are the usual symptoms for ECU failure? Will the car still be started but cant rev up? CEL? Its a 93 Legacy Thanks for the help Link to comment Share on other sites More sharing options...
tcspeer Posted March 26, 2006 Share Posted March 26, 2006 If the car wont rev. up there is a chance the inside of the muffler has collapsed. Check the tail pipe and make sure someone has not stuck something in it. What are the usual symptoms for ECU failure? Will the car still be started but cant rev up? CEL? Its a 93 LegacyThanks for the help Link to comment Share on other sites More sharing options...
ra_der Posted March 26, 2006 Share Posted March 26, 2006 I've only come across one bad ECU, and that was when I revived a junkyard car. It would run and idle, but would only rev to about 2500 with no power. Totally unacceptable to drive. And it threw all kinds of wierd codes that would change every time I checked them, no matter what I changed or plugged it had no effect on the codes I would get. I changed the ECU and it was magic. Link to comment Share on other sites More sharing options...
