Phizinza Posted March 26, 2006 Share Posted March 26, 2006 Ok, How much of the wiring needs to be moved over? As in, is it just a bunch of wires from the engine to the ECU, or is it all intergrated in the wiring loom, and does that mean I have to take the whole loom out of the 82t and into the 81? Just say I have a complete EA82T donor XT. I should have everything I need right? So by my research I should have to do something along the lines of: Take the engine and crossmember and put in in the EA81. I will also use the exhuast out of the EA82T. Put the ECU in and the wiring. Anything else? Thanks. Link to comment Share on other sites More sharing options...
subiemech85 Posted March 26, 2006 Share Posted March 26, 2006 fuel pump, radiator Link to comment Share on other sites More sharing options...
Phizinza Posted March 26, 2006 Author Share Posted March 26, 2006 Fuel pump, that's the only thing the car doesn't have. So, can I use any "XXXHP" fuel pump. Or do I have to use a EA82t original one? Link to comment Share on other sites More sharing options...
bpm Posted March 27, 2006 Share Posted March 27, 2006 Fuel pump, that's the only thing the car doesn't have. So, can I use any "XXXHP" fuel pump. Or do I have to use a EA82t original one? i used an efi pump from a ford f250 as it had the 8mm sized intake which makes things a hellava lot easier. screwed it up under the tray in a coil bracket and ran a wire through the chassis rail up to the front where i used a relay to switch it. the only prob doing it this way is that the brumby return line is tiny, not really big enough for an efi car. you can run a new one in fuel hose, just make sure its well protected and secure. Link to comment Share on other sites More sharing options...
jaacina Posted April 7, 2006 Share Posted April 7, 2006 I am looking to do a similar swap... but I would replace my '92 SPFI Loyale with an '87 Turbo MPFI from an XT. I was told that the wiring harness will be nightmare due to the digital dash issue. Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted April 7, 2006 Share Posted April 7, 2006 Ok,How much of the wiring needs to be moved over? As in, is it just a bunch of wires from the engine to the ECU, or is it all intergrated in the wiring loom, and does that mean I have to take the whole loom out of the 82t and into the 81? Just say I have a complete EA82T donor XT. I should have everything I need right? So by my research I should have to do something along the lines of: Take the engine and crossmember and put in in the EA81. I will also use the exhuast out of the EA82T. Put the ECU in and the wiring. Anything else? Thanks. I saw your post on msefi.com I would just build a MS harness and not worry about any of the stock turbo wiring. Link to comment Share on other sites More sharing options...
Phizinza Posted April 8, 2006 Author Share Posted April 8, 2006 I saw your post on msefi.com I would just build a MS harness and not worry about any of the stock turbo wiring. Yeah, it turns out I am not going to be getting a EA82T. So I have other ideas. I agree, I don't see why more people are just dumping the old harness and using MS. It seems it would be easier and more adjustible. I guess theres a lot of tuning to do though. But as I said, on to my other idea. I will post more about it as I get it in motion. Link to comment Share on other sites More sharing options...
