pitstain Posted March 27, 2006 Share Posted March 27, 2006 Hi guys nice board you got here....I tried searching to see whats up with this 98 legacy wagon i got from my mom-in-law....it leaks a little oil...otherwise runs ok....dont know if its valve cover gaskets or head gaskets maybe a front crankseal?? also i see parts talking about BEFORE 5/98 and after 6/98, im a little confused.....i have the VIN handy if someone can decode it... i have seen a few posts talking about phase1 and 2 engines? i really dont want to dump a ton of cash into this car...it gets 350 miles to a tank of gas and i can leave my 14mpg lightning in the garage during winter and yucky days now. Thanks in advance for all the help Ian Quote Link to comment Share on other sites More sharing options...
seattlelegacy Posted March 27, 2006 Share Posted March 27, 2006 All subarus leak oil. Its one of those things we love about them! Really though, the seals that leak the most frequently are the Valve cover gaskets, oil pan, and front and rear mains. the front and rear mains can be a pain to replace, but the others are pretty easy (I've been told). Quote Link to comment Share on other sites More sharing options...
pitstain Posted March 27, 2006 Author Share Posted March 27, 2006 Thanks, well i think ill buy valve cover gaskets and try to do it myself. ?'s which gaskets do i get ? early 98 or late i have no idea when this car was built...all i know is it has the 2.2 motor...and are there other things to replace on the covers when i do the main gaskets...ive seen plug hole seals and other thingys....if anyopne has part numbers that would be great...thankyou Quote Link to comment Share on other sites More sharing options...
dmanaenk Posted March 27, 2006 Share Posted March 27, 2006 Open drivers door and look around the door frame. There should be a metal plate with production month. Quote Link to comment Share on other sites More sharing options...
pitstain Posted March 27, 2006 Author Share Posted March 27, 2006 cool thanks another little problem is the tailgate will not open via the handle you have to stick a screwdriver in the latch from inside the car to work it....any ideas? Quote Link to comment Share on other sites More sharing options...
3Pin Posted March 27, 2006 Share Posted March 27, 2006 On the rear door latch, wd 40 the handle above the license plate and work it back and forth until the handle starts working again. This is really common. Good luck on the gaskets. Quote Link to comment Share on other sites More sharing options...
pitstain Posted March 27, 2006 Author Share Posted March 27, 2006 WD40.....ok thanks alot i feel like such a newbie im out of my usual ford truck forum element Quote Link to comment Share on other sites More sharing options...
pitstain Posted May 30, 2006 Author Share Posted May 30, 2006 ok guys...i have the car now....tailgate handle is TOAST....it is so rusted it wont budge.....also the brakes pulsate BADLY when i get on the stop pedal.....warped front rotors me thinks....really scary probably takes 150 feet to stop from 45mph......my lightning goes from 60mph to zero in just over 90 feet.......i was gonna do hawk hps pads up front with some slotted rotors. a few questions..... where is the fuel filter and what size tool do i need for it? is there a reccomened maf adapter of some sort to bolt on a nice big open element filter to the intake? i have a raman alternator i will assume it should survive a while. is there a good H.I.D. conversion for this thing? maybe some prejectors from japan? these stock headlights are not the best...what are the stock bulbs? no two sites give the same info some say h4 some say 9007 ? Thanks guys Quote Link to comment Share on other sites More sharing options...
JPX Posted May 30, 2006 Share Posted May 30, 2006 Fuel filter is right next to the washer tank with three fuel hoses. Just need a philips screwdriver and possibly a pair of pliers to pull the hoses off. About $25 from the dealer I think. Buy new rotors.....but make sure your calipers' pistons aren't sticking. Quote Link to comment Share on other sites More sharing options...
pitstain Posted May 30, 2006 Author Share Posted May 30, 2006 thanks for the info......whats the best place to buy new calipers if i wanted to.......subaru told me my leg was built in oct of 1997 thanks again Quote Link to comment Share on other sites More sharing options...
Juan Posted June 1, 2006 Share Posted June 1, 2006 Is your Subaru made in US? It is my understanding that the Brighten model was discontinued in 1997. Juan Quote Link to comment Share on other sites More sharing options...
pitstain Posted June 1, 2006 Author Share Posted June 1, 2006 it is a 98 brighton according to subaru customer service it was built october 1997.....I don't know where it was built. ok so I did the fuel filter, pcv valve, air filter, and am putting in new ngk laser patniums tonight, the engine makes a bit of a clanging deisel sound or two stroking noise though........ Quote Link to comment Share on other sites More sharing options...
