Caboobaroo Posted March 28, 2006 Share Posted March 28, 2006 So discussing this matter with kingbobdole, having my own FSM for a spyder intake, and a cut apart 3-pin harness, I'm still having issues on figuring this all out. Now the 3-pin harness only has 2 wires going into the TPS, whereas according to my FSM for the spyder intake, there's 4 wires going into the TPS. I have specs for the spyder TPS as far as voltages and whatnot, but she still has this hesitation I mentioned in another post. So, experts, how do I retrofit a 3-pin TPS onto my spyder intake? I can cut apart my 4-pin harness on the spyder if need be, thats not a problem but having a basic wiring diagram would help greatly! If its a matter of cutting and splicing a couple wires together and mounting the TPS, I can do that but without the FSM for the 3-pin TPS, I'm totally lost. Also, on the 4-pin harness, it shows the wires going into different spots on the ECM, or is it because the ECM from an XT is totally different from a regular EA82 MPFI ECM? Thanks for all the help since I gotta get my RX on the road ASAP! Link to comment Share on other sites More sharing options...
Subarutex Posted March 28, 2006 Share Posted March 28, 2006 If you actually look at the 2 TPS's, you'll find they move oppositie directions... thus, not interchangeable without a good amount of modification. 85-86 TPS's are different from 87+ TPS's which are different than spider manifold TPS's. I used the spider TPS. Do I have issues? probally, but that is not the cause of the hesitation. Try more timing. Hesitation will go away, then your head gaskets will go BOOM! I always thought my hesitation was cams and/or turbo. We shall see with this new motor. No delta cams, and VF11 FTW. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 28, 2006 Author Share Posted March 28, 2006 so I'm guessing you used the TPS for the spyder intake cause I believe you used a NA intake like I did. From what you're saying is just to leave it as is and it should be fine? Just mess with the timing and get her goin huh? I'll just have to do that... Also, since you decided to respond to this post as well, how did you make the AAV fit? Mine is hitting the outlet on my TD04. If anything, I can put it on the firewall and run a couple new lines to it with the wiring as well... Link to comment Share on other sites More sharing options...
Subarutex Posted March 28, 2006 Share Posted March 28, 2006 is that the disc looking thing with the 2 hose connections on it, and a tube coming out the other side with the wiring connecter on it? Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 28, 2006 Author Share Posted March 28, 2006 yup, that would be the thingy that I have sitting on a shelf in my garage cause I don't know what to do with it:grin: Link to comment Share on other sites More sharing options...
Subarutex Posted March 28, 2006 Share Posted March 28, 2006 For awhile I ran without it. But, while trying to fix idle and hesitation issues I put it back in. I put it at the stock spot on the manifold, however, just move it towards the center of the manifold, and only use one of the bolts to hold it in. Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 29, 2006 Author Share Posted March 29, 2006 For awhile I ran without it. But, while trying to fix idle and hesitation issues I put it back in. I put it at the stock spot on the manifold, however, just move it towards the center of the manifold, and only use one of the bolts to hold it in. thats what I have been thinking I was going to have to do. Good thing I got tons of spare intake gaskets. Thanks Tex! Link to comment Share on other sites More sharing options...
subyrally Posted August 25, 2006 Share Posted August 25, 2006 sorry to drag up an old thread, but did anyone ever figure out how to wire up the 4 wire to the 3 wire harness? i think i read somewhee that three of the wires were the same function as the three wire and the fourth was something about idle enrichment or something to that effect that the xt needed. ive got the spyder manifold with the xt6 throttle body on it it the machine shop and i should be getting it back on monday. Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 25, 2006 Author Share Posted August 25, 2006 well mine seemed to work out pretty decent. I dunno about Tex but the only issue I had was the fact that my car would have a weird idle. Sometimes it would idle, sometimes it wouldn't but I think that had to do with other tuning issues. Link to comment Share on other sites More sharing options...
subyrally Posted August 26, 2006 Share Posted August 26, 2006 well mine seemed to work out pretty decent. I dunno about Tex but the only issue I had was the fact that my car would have a weird idle. Sometimes it would idle, sometimes it wouldn't but I think that had to do with other tuning issues. sooo, how did you wire it up? also, how did you get the throttle cable linked up? Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 26, 2006 Author Share Posted August 26, 2006 Well what I did was what Tex did on the TB. I rotated it 90 degrees so the throttle linkage was sticking straight up, used my stock throttle cable and modified it to work. For the TPS, I had to wire in my knock sensor but I used the spyder intake wiring harness and plugged it right into my body harness. Link to comment Share on other sites More sharing options...
