Ever Victorious Posted March 29, 2006 Share Posted March 29, 2006 Well, my brother-in-law's genius friends have screwed me over somewhat. I had taken Freebie's coil out and tried it in the t-coupe to see if that would change anything (because the spark was kinda weak) but it didn't. I then got sick and couldn't change it back. In the mean time, my BIL came to buy freebie off of me, and needed the coil put back in it. I told his friend to remove freebie's coil and REPLACE it with the turbo's original coil. Of course, he didn't do that, and now I have 5 little wires that I have absolutely NO clue where they go. Only one I know is the plug wire, which is obvious. Anyone with a tcoupe able to tell me where each of the 5 wires goes? Link to comment Share on other sites More sharing options...
Ever Victorious Posted April 2, 2006 Author Share Posted April 2, 2006 Noone has an answer? Link to comment Share on other sites More sharing options...
carfreak85 Posted April 2, 2006 Share Posted April 2, 2006 Are these five little wires near the coil? I assume if they are that they go to the positive and negative poles on the coil. I don't have my manuals with me, but the answer would be in there for sure. Link to comment Share on other sites More sharing options...
Ever Victorious Posted April 2, 2006 Author Share Posted April 2, 2006 Are these five little wires near the coil? I assume if they are that they go to the positive and negative poles on the coil. I don't have my manuals with me, but the answer would be in there for sure. Yes, I know they go to the + and - terminals of the coil, because that's where they were pulled from, but the little snothead that pulled the other coil out didn't put this coil in its place like I asked, so I have no idea which little wires go to which terminal. That is what I am asking. I sadly do not have the luxury of a manual to assist me in this. My only manual is for EA82's and EJ22's. Link to comment Share on other sites More sharing options...
carfreak85 Posted April 2, 2006 Share Posted April 2, 2006 Hmmm, with both my turbo specific manuals an hour and a half away from school, I won't be able to help you for a while. Next weekend I can help you though. Link to comment Share on other sites More sharing options...
naru Posted April 2, 2006 Share Posted April 2, 2006 You should have 5 small gauge wires in addition to the HT lead. 3 blacks to coil +. 2 yellows to coil -. Link to comment Share on other sites More sharing options...
Ever Victorious Posted April 3, 2006 Author Share Posted April 3, 2006 You should have 5 small gauge wires in addition to the HT lead.3 blacks to coil +. 2 yellows to coil -. Excellent, I'll try that, thanks. Link to comment Share on other sites More sharing options...
Ever Victorious Posted April 4, 2006 Author Share Posted April 4, 2006 whoopsie... Turns out there's 6 wires... 2 yellow, 2 black and white, 1 black (I assume these are the aforementioned wires that go to respective terminals)... but then there's a GRAY wire?! Where's that from? Link to comment Share on other sites More sharing options...
naru Posted April 4, 2006 Share Posted April 4, 2006 whoopsie... Turns out there's 6 wires... 2 yellow, 2 black and white, 1 black (I assume these are the aforementioned wires that go to respective terminals)... but then there's a GRAY wire?! Where's that from? Oops,missed that one.It goes w/the yellows. Link to comment Share on other sites More sharing options...
carfreak85 Posted April 4, 2006 Share Posted April 4, 2006 Both black/whites and the black wire go to the positive side of the coil, everything else goes to the negative terminal. Link to comment Share on other sites More sharing options...
