84 t-coupe wiring dilemma
Well, my brother-in-law's genius friends have screwed me over somewhat.
I had taken Freebie's coil out and tried it in the t-coupe to see if that would change anything (because the spark was kinda weak) but it didn't. I then got sick and couldn't change it back.
In the mean time, my BIL came to buy freebie off of me, and needed the coil put back in it. I told his friend to remove freebie's coil and REPLACE it with the turbo's original coil. Of course, he didn't do that, and now I have 5 little wires that I have absolutely NO clue where they go. Only one I know is the plug wire, which is obvious.
Anyone with a tcoupe able to tell me where each of the 5 wires goes?
  carfreak85 said:
Are these five little wires near the coil? I assume if they are that they go to the positive and negative poles on the coil. I don't have my manuals with me, but the answer would be in there for sure.
Yes, I know they go to the + and - terminals of the coil, because that's where they were pulled from, but the little snothead that pulled the other coil out didn't put this coil in its place like I asked, so I have no idea which little wires go to which terminal. That is what I am asking.
I sadly do not have the luxury of a manual to assist me in this. My only manual is for EA82's and EJ22's.
  Ever Victorious said:
whoopsie...
Turns out there's 6 wires... 2 yellow, 2 black and white, 1 black (I assume these are the aforementioned wires that go to respective terminals)... but then there's a GRAY wire?!
Where's that from?
Oops,missed that one.It goes w/the yellows.
