how to clean my disty?
Electric motor cleaner (Lectramotive) or good old WD-40 should do the trick, blowing it out with air will help too, but I would also recommend disassembly or at least partial disassembly because you will want to re-grease the mechanical advance mechanism and re-oil the vacuum advance plate bearing (the cleaner will wash out all the lube).
Gary
Complete dissasembly is not hard at all, then you can use whatever cleaner you want. Check the shaft play in it too. If it's a ND then there should be NO shaft play at all. The Hitachi units will tollerate a bit more, but it still shouldn't be much. There's a place up here in P-town that will rebush the shaft for $35
