OK, here are the clues...:-\
1. 91 Legacy 5spd
2. EJ22 non turbo
3. located @ the front top center edge, below the alternator, in front of the " EJ22 " stamp on the block.
Have a guess yet??? :confused:
Here are more clues...
4. It is approx 3" long cylinder mounted vertically.
5. It has an approx 20mm hex molded at the top for removal.
6. It is attatched w/a single conductor, w/a spade type connector @ the top.
7. It sometimes "burps" oil up through the center ( between the dialectric and conductor) and leaves your engine stinky when it warms-up.
:burnout:
It is the electrical oil pressure sender.
On my car I've connected a T fitting to the port with the sender on one end and a copper tube on the other leading to a mechanical oil pressure gauge.
What is there to win???
