  Dickensheets said:
Why is the Forrester the only model offered with the viscous LSD in the rear? I think it would be a nice option for the Outback and the Baja as well.
rd
It isn't. 05 7 06 Outbacks have LSD, although the Legacy does not except the GT.
  Quote
Continuous AWD: Models equipped with 5-speed manual transmission utilize a viscous-type locking center differential and limited-slip rear differential with torque distribution normally configured at a 50/50-split front-to-rear. If wheel speed differs between front and rear axles, the system helps distribute power to the wheels with the most traction.
Active AWD: Models equipped with 4-speed automatic transmission utilize an electronically controlled variable transfer clutch and limited-slip rear differential to distribute power to where traction is needed. Sensors monitor parameters such as wheel slippage, throttle position and braking to help determine torque distribution and direct it to the wheels with optimum traction.
  Dickensheets said:
The next question is how do I get one to transplant into my 97obw? I'm guessing it would plug and play, right?
you may think twiice about this. First they hard to find, second you may have to change the gearing in thr front, third they really arent all that responsive like the old limited slips were. You would do better by slightly riding your brakes if your that stuck then all the trouble for a viscous differential.
nipper
  Dickensheets said:
Wow cool!
Thanks I feel better now. I was going by what's on Sube's official website. They should make this a selling point.
Thanks guys.
The stuff I quoted is from the website.
A two-edged sword, though.
  Dickensheets said:
Can you explain what you guys are getting at? I thought LSD was the bomb.com offroad.
Limited slip differential is the bomb for off road, but this is a viscous LSD. The regular LSD is a mechanical clutch design that responds instantly. The viscous type is lighter, cheaper to make, and slower to respond. The wheel has to spin for some revolutions to heat up the fluid before its starts to engage, and even then its slowly builds up.
nipper
nipper
OK - does the above apply to REAR LSD? Because it's my understanding the center diff (on my MT WRX) is viscous LOCKING. Not just viscous plates .
acoording to this;
http://www.autozine.org/technical_school/traction/tech_traction_4wd_2.htm
Subaru uses (or has used) viscous locking center diffs with just viscous rear diffs. Is that true nowadays?
Carl
acoording to this;
Carl
It is not "locking". You can see the drawing on the link you gave. How can it possibly "lock"?
number 3 at the bottom. It specifically mentions Subaru along with the other vehicles.
I just don't know if there have been changes since that was written(or even if its correct).
Carl
Carl
link tells me 401 not found. Otherwise i would jump back in the discussion.
nipper
Carl
Do you have a button someplace that locks the center diff? Otherwise where did you get that info. Audis and other cars with full time AWD can manually lock the center differential with the push of a button.
nipper
nipper
halfway down the following page it says VLCD and limited slip rear;
http://www.cars101.com/subaru/impreza/wrxsti2006.html
so, evidently the info on that other page (sorry about the 401, works for me) is still current.
wow! looks like I can paste it in! cool! (if it goes through OK)
3) Viscous Coupling Differential Lock
  • tech_pic_traction_diff_lock.jpgWhile Torsen 4WD is too expensive, Viscous-Coupling LSD is part-time only, most 4WD cars, including the rally ace Celica GT4, Subaru Impreza, Mitsubishi Lancer and Ford Escort RS Cosworth adopted another kind of center differential - basically it has a regular center differential which distribute torque to front and rear under normal condition, an additional Viscous Coupling Differential Lock provides anti-slip function when needed.Characteristic of this system
    The Viscous-Coupling Differential Lock is virtually the same as what we have learned earlier, therefore it also has slight delay and non-linear characteristic. However, in reality this might not be as serious as we thought, otherwise it would have been impossible that all the top rally cars use it. Moreover, Viscous-Coupling Differential Lock system is lighter and cheaper than Torsen system, while having superior effectiveness over the part-time Viscous-Coupling LSD system.
    Advantage: Good balance between price and effectiveness Disadvantage: No special flaw Who use it ?
  • Lancia Delta Integrale (with Torsen in rear axle)
  • Ford Escort RS Cosworth (with Viscous-Coupling LSD in rear axle)
  • Mitsubishi Lancer GSR, 3000 GT VR4. (with Viscous-Coupling LSD in rear axle)
  • Subaru Impreza and Legacy manual versions (with Viscous-Coupling LSD in rear axle)
  • Toyota Celica GT4 (with Torsen in rear axle)
  • Bugatti EB110 (set to 70% rear bias)
  MountainBiker said:
Again, locking is the wrong term. It is a viscous coupling.
sigh, here's that entire page;
Different types of 4WD
  • 1) Torsen differential - Audi Quattro system*
  • Being the master of 4-wheel drive, Audi always insists to use the most effective system despite regardless of price. Its Quattro 4WD system* uses a pure mechanical LSD, Torsen differential.Torsen, means "torque-sensing", was invented by an American company calls Gleason Corporation. Its slip-limiting ability is implemented by cleverly using worm gears / worm wheel pair. This pair has a special characteristic: driving torque can be transfered from worm wheel to worm gear, but not reverse. Otherwise, they will be locked up. It is such characteristic that limit slip.
    tech_pic_traction_torsen.jpgA: Differential housing
    B: Out axle
    C: Worm wheel
    D: Worm gears
    E: Synchromeshes
    F: Hypoid wheel (from engine)
    G: Out axle
  • The above picture explains how Torsen differential works. In normal cornering, i.e., no tyre slip in any wheel, Torsen differential provides the same function as a normal differential. The addition of worm wheel / worm gear pair does not affect speed difference between output shafts. For instance, if the car turns left, the driveshaft to right wheel runs faster than the differential housing, while the driveshaft to left wheel runs slower than the differential housing. The speed difference between left and right worm wheels can be exactly matched in the synchromesh gears. Note that the worm gears / worm wheels pair do not lock up because torque is transfered from worm wheels to worm gears.When one of the wheels, say the right wheel, loses traction due to poor road surface or whatever reason, the worm gear / worm wheel pair get into effect. At the instant just before they become effective, one must know that by the basic differential theory no torque will be sent to the left wheel, which is with traction. Instead, all the torque will be sent to the spinning right wheel. Then, the fast-rotating right worm wheel will drive its worm gear, through the synchromesh and drive the left worm gear. Now, do you still remember the basic characteristic of worm gear / wheel pair ? Well, when worm gear drives worm wheel, they will be locked up. As a result, the left worm gear and right worm gear are actually locked together, thus wheels on both side will rotate at the same speed and get the car out of the lose of traction.
    Characteristic of Torsen-equipped 4WD
    Except the first generation Quattro system that appeared in the early Quattro coupe, most of the subsequent Quattro systems used Torsen differential in center and rear axles. This is rather expensive. However, Torsen-equipped 4WD has many advantages. First of all, its pure mechanical parts react almost instantly to tyre slip. Secondly, it provides linear lock-up characteristic. Thirdly, it is a strictly permanent 4WD system. In normal condition, torque split between front and rear wheels is 50:50 (other ratios are possible, depends on the pitch of worm gears).Apart from Audi, few other car makers adopted Torsen LSD, mainly because of cost reason. Toyota's rally ace, Celica GT4 was one of the few exception. It used Torsen in the rear axle. This might be part of the reason why it was so expensive over competitors.
    Advantage: Quick response, permanent 4WD Disadvantage: Pricey, torque split not variable Who use it ? All non-Golf-based Audi quattro models, Toyota Celica GT4, Hummer etc.
    Note: * the "Quattro" mentioned here is the traditional Torsen system marketing in the name Quattro. That includes all Quattro models until the arrival of Audi TT (which uses the Haldex system). Since then the name Quattro becomes a marketing trade mark rather than indicating the actual mechanism. At the time of writing, all Audi Quattro models, excluding the Golf-based A3, S3 and TT, still employs the traditional Torsen system.
  • 2) Viscous-Coupling differential
  • Viscous Coupling center LSD is commonly used in many simple 4WD systems. One of the earliest examples was Volkswagen's Syncro system.tech_pic_traction_viscous_diff.jpgtech_pic_traction_viscous_2.jpg
    Inside a viscous coupler as shown in the right hand side picture, there are many circular plates positioning very close to each other. Both drive shafts connect to roughly half of the plates in an alternating sequence as shown. The sealed differential housing is fully contain of a high viscosity liquid, which has a strong tendency to "visco" those plates together.
    In normal condition, front and rear axles run at roughly the same speed so the plates and viscous liquid are relatively stable to each other. When tyre slip occurs in one of the axle, that means the alternating plates run at different speed, viscous liquid will try to visco them together. As a result, torque is transferred from the faster driveshaft through the liquid to the slower driveshaft. The greater the speed difference, the larger the torque transfer. As a result, limited slip function is implemented.
    Characteristic of Viscous Coupling center differential
    Note that Viscous-Coupling LSD is a speed-sensing device: under no-slip condition, no torque will be sent to another axle. Whenever slip occurs, theoretically up to 100% torque can be sent to any axle, depending on the traction difference between front and rear axle. Therefore it is a part-time 4WD.Being a part-time 4WD, it does not have the neutral steering of a permanent 4WD can obtain. For cars based on rear-wheel drive models, such as Porsche 911 Carrera 4, this is not a real problem - as normally the car runs like a RWD car thus is capable to deliver the desirable throttle oversteer . However, for other front-wheel drive-based cars like VW Golf Syncro and Volvo 850 AWD, the part-time 4WD can do nothing to correct their understeering manner. This is the first disadvantage.
    The next problem is the delay before the 4WD get into effective. Since viscous liquid is not a fixed medium (unlike gear), it takes time and speed difference to be effective. The function between speed difference and torque transfer is an exponential function - that means in the early stage of slip, torque transfer remains near zero.
    To cure this problem, most manufacturer varies the final drive ratio such that introduce a slightly speed difference even in normal condition. As a result, the car actually runs with 95:5 torque split between front and rear. This shorten the delay time. However, it is still impossible to match the pure mechanical Torsen LSD.
    It might be less effective than Torsen system, but it is certainly the cheapest, so we can find it in many mass production 4WD cars.
    Advantage: Cheap and compact Disadvantage: Part-time 4WD only. Normally feels like 2WD. Who use it ? VW Syncro, Lamborghini Diablo VT, Porsche 993/996 Carrera 4 and Turbo, Volvo 850 AWD etc.
  • 3) Viscous Coupling Differential Lock
    as you can see, viscous coupling is different from viscous locking.
    I dunno. maybe the website is wrong plus I misunderstand what is written at cars101.com.
    Carl
Cool article, I had wondered how the honda awd system worked.
I think the page is a bit misleading when the use the term 'locking'. While the VC attached to the rear of our 5MT's does provide a limited slip function (like the diagram says) it isn't a true locking coupling in the sense of a physical gear or clutch.
With that said I believe that the center VC and the rear vLSD function basically the same.
I've seen that page many times, and I got your point the first time. THe fact remains that it is not locking in any way. In fact, the two drawings show the same thing for the viscous coupling and the viscous locking (sic), with the only difference being that one is more of a schematic representation, while the other is a cutaway of the real part. You can even see that on the picture of the viscous locking (sic), is says "VC Sip Limiter". Assuming they meant Slip Limiter, it is still a limited slip unit, not a locker. I'm done.
Well, I guess to be on topic, the REAR diff is VC as listed at cars101, and its function is likely the same as shown in the diagram numbered '2'.
I THINK though, that the viscous plates in the CENTER diff. actuate a device in the diff itself to cause it to unlock. While locked, it would distribute 50/50 power to fron and rear axles.
according to this scan from a Subaru manual;
http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWDMT_description.jpg
"The viscous coupling serves as a differential-action control."
(again, this is the CENTER diff which is not on topic for this thread)
maybe I'm wrong. I frequently am.
Carl
