NewDriverOlderRide Posted April 2, 2006 Share Posted April 2, 2006 Ok I have a 93 Loyale S/w PshButton 4WD 5 Spd. Manual. And the 4wd doesn't work. I dont know how to get it to. Nothing happens when I press the 4WD button, no lights, flashes, strobes, buzzes, whistles, etc. So uhh.....Where do I start? Link to comment Share on other sites More sharing options...
rllywgn Posted April 2, 2006 Share Posted April 2, 2006 it's been a while since ive had a push button car.. but as i recall.. theres a fuse near the passenger side strut tower.. if thats not bad.. theres a vacuum operated selenoid just above the trans but closer to the drivers side.. those have been known to fail.. hope this helps and good luck rllywgn Link to comment Share on other sites More sharing options...
Phizinza Posted April 2, 2006 Share Posted April 2, 2006 Umm, maybe you stiped the button?! Nah, sorry man! I would start by looking at the wiring on the button. Then following the wiring back from the button, which I would imagin would go into the dash somewhere. I would also assume that the button would lead to a coupld of wires on the gearbox. Kinda like the reversing light wires. But as you probably know, I have never owned, or seen a push button subie setup. I'm just guessing. Link to comment Share on other sites More sharing options...
ballitch Posted April 2, 2006 Share Posted April 2, 2006 ya the vacuum solenoids have been known to fail. and the wiring could be slightly corroded. if you search for the trouble shooting of the vacuum solenoids, you might find out its the solenoid and not the wiring, but check the wiring first. ~Josh~ Link to comment Share on other sites More sharing options...
subiemech85 Posted April 2, 2006 Share Posted April 2, 2006 or get rid of all that crap and install a lever Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 2, 2006 Share Posted April 2, 2006 there are two solenoids on the driver side near the wiper motor. Make sure that these: -click when you hit the button -have vacuum to them from the intake manifold If either of those don't work, well, you won't have 4WD Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 2, 2006 Author Share Posted April 2, 2006 Thanks for the replys, I'm going to go look for these things right now. How can I tell if the car goes into 4WD? Is there a dash light? Link to comment Share on other sites More sharing options...
oskar_subaru Posted April 2, 2006 Share Posted April 2, 2006 Yes there is a 4WD light in the midle of the car sign in the dash Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 2, 2006 Author Share Posted April 2, 2006 Ok UPDATE: Ok After fooling around with your suggestions I have noticed some good and bad things, bad - I think the 4WD dashlight might be burnt out? unless it only turns on when 4WD is actually ENGAGED? and 4WD still doesn't work. Good- Button and vacuum/Solenoid seem to be working because when I press the button I hear it click and it hisses air when I first press it. Does that mean theres a possible leak, or is that normal? So I need to know where the lever or w/e the vacuum engages for 4WD is located? Do I need to remove the skid plate to access it? pics are appreciated if possible. Oh, and rllywagon I changed the fuse with no effect. Link to comment Share on other sites More sharing options...
Spiffy Posted April 2, 2006 Share Posted April 2, 2006 a lot of people have vacuum problems going to that solenoid... the vacuum is supplied by a white canister in the engine compartment on the passenger side up by the hood hinge... make sure that the canister is holding pressure... you can also just suck on a long hose connected to the solenoid on the driver side that actuates it... and check the wiring from there to the tranny... you should be able to follow the slow of things... manifold vacuum, canister, solenoid, tranny... at least it sounds like the solenoid is engaging by the click you hear... --Spiffy Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 2, 2006 Author Share Posted April 2, 2006 bump..... Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 2, 2006 Share Posted April 2, 2006 There used to be a nice troubleshooting guide to this 4WD system in the USRM, but I guess it got lost in the shuffle to the new system? on the driver side top of the tranny is a large vacuum baffle thingy. When you (or an assistant) click the button, you should be able to see it move. If it doesn't move, you have a vacuum leak before that point. I think it should give a little hiss of air during normal usage.. not sure though. Out of curiosity, how do you know it's not going into 4WD? Link to comment Share on other sites More sharing options...
MilesFox Posted April 2, 2006 Share Posted April 2, 2006 do this once: change the heater vent selections fro DEF, BILEV, FLOOR, etc. if all of these settings blow out of the DASH VENTS only, thgis will confirm a vacuum issue look for a rather skinny line coing off the passenger side of the intake going to the vac canister. a lot of ties this falls off when working under the hood, and is overlooked! also follow the plastic lines fro the vac canister to the other side of the car Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 3, 2006 Author Share Posted April 3, 2006 UPDATE! OK after fooling around with it heres what my grandpa and I discovered. 1. There doesn't seem to be enough suction getting to the lever thing. However, there don't seem to be any leaks or cracks...all of the vacuum connections suck at about 20(on a vacuum meter guage thingy) 2. We discovered that you can get it into 4WD by taking the right solenoid hose and switching it to the left solenoid(the one that is activated by pressing the 4WD button) and plugging the left hole with the tip of my finger(This was with the button at the ON position) This caused the dash light to come on also. 3. While taking the car for a quick spin while making sharp turns the rear was similar to a live (1 piece) axel. the inside wheel would spin, while the outside wheel would slide. Not good. 4. It also got stuck in 4WD until I drove in reverse. So what do yall think? Tyler PS. I knew beforehand the 4WD didnt work because I jacked all the wheels up, and the fact that the dash light wasn't on. Link to comment Share on other sites More sharing options...
MilesFox Posted April 3, 2006 Share Posted April 3, 2006 1. There doesn't seem to be enough suction getting to the lever thing. However, there don't seem to be any leaks or cracks...all of the vacuum connections suck at about 20(on a vacuum meter guage thingy) the 4wd is actuated by vacuum to a diaphragm at the transmission. check your vacuum there. suppose the diaphragm itself has a leak? 2. We discovered that you can get it into 4WD by taking the right solenoid hose and switching it to the left solenoid(the one that is activated by pressing the 4WD button) and plugging the left hole with the tip of my finger(This was with the button at the ON position) This caused the dash light to come on also. Suppose the 4wd was working to begin with, switching these hoses will cause the swithc to work inversely. that is, when the button os off the 4wd will be engaged, and it will disengage when pressed 3. While taking the car for a quick spin while making sharp turns the rear was similar to a live (1 piece) axel. the inside wheel would spin, while the outside wheel would slide. Not good. torque bind fro the differences in rotation between the front and rear axles across the transission 4wd "transfer case" (really a direct drive off the front diff) 4. It also got stuck in 4WD until I drove in reverse. same as above. 4wd should be used only on slippery surfaces, ud, snow, sand, gravel HEAVY rain. engage and disengage 4wd with the steering straight ahead while moving. what you describe is typical of 4wd engageent such as when you drive onto a dry surface before disengaging it So what do yall think? i think this: we know the 4wd mechanism itself works. you know you have vacuum. i would suggest the diaphragm is bad on one side, or there may be a vac leak between the solenoids and the diaphragm if you disconnected the diaphragm fro the threaded rod to the tranny you can manually operate the 4wd mechanism in the tranny. this is what subieecch refers to by "getting rid of all that crap and install a lever" to source another diaphragm, any will work fro any 4wd pushbutton tranny, or any full tie tranny with a diff lock one more thing you can try is: do like you did switching the vac lines to engage the 4wd this way. then re-connect them like they were, then turn the button off to see if it disengages. if this works, then you have no vac on the engage side of the diaphragm if this does not work, then you possibly have no vac to the engage solenoid, or that solenoid couldbebad. check for volts at both solenoids Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 3, 2006 Author Share Posted April 3, 2006 hmm. Link to comment Share on other sites More sharing options...
Subaru in the Rainfroest Posted April 3, 2006 Share Posted April 3, 2006 i agree with fox just swiych to a lever. from what i sen here it would save a lot of problem in the long run. but the just opinion. Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 3, 2006 Author Share Posted April 3, 2006 Are there any kits or plans etc. to do this, or do I have to fab something up? How hard a job is it? Also. torque bind fro the differences in rotation between the front and rear axles across the transission 4wd "transfer case" (really a direct drive off the front diff) ^^^--So that is supposed to happen? I don't understand? Link to comment Share on other sites More sharing options...
Numbchux Posted April 3, 2006 Share Posted April 3, 2006 or get rid of all that crap and install a lever yea, it'll be easy while you're doing that DR swap So that is supposed to happen? yes Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 3, 2006 Author Share Posted April 3, 2006 yea, it'll be easy while you're doing that DR swap yes Unnecessary, I've decided that I'm gonna just keep it my daily driver, I don't reckon that I'll have it that long anyway. Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 4, 2006 Author Share Posted April 4, 2006 """"if you disconnected the diaphragm fro the threaded rod to the tranny you can manually operate the 4wd mechanism in the tranny. this is what subieecch refers to by "getting rid of all that crap and install a lever"""" Are there any kits or plans etc. to do this, or do I have to fab something up? How hard a job is it? Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted April 4, 2006 Author Share Posted April 4, 2006 """"if you disconnected the diaphragm fro the threaded rod to the tranny you can manually operate the 4wd mechanism in the tranny. this is what subieecch refers to by "getting rid of all that crap and install a lever"""" Are there any kits or plans etc. to do this, or do I have to fab something up? How hard a job is it? Bump12345 Link to comment Share on other sites More sharing options...
86 BRAT Posted April 4, 2006 Share Posted April 4, 2006 Ok I have a 93 Loyale S/w PshButton 4WD 5 Spd. Manual. And the 4wd doesn't work. I dont know how to get it to. Nothing happens when I press the 4WD button, no lights, flashes, strobes, buzzes, whistles, etc. So uhh.....Where do I start? If the vacuum lines are dry or cracked, replace them they cause all kinds of headaches. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 4, 2006 Share Posted April 4, 2006 """"if you disconnected the diaphragm fro the threaded rod to the tranny you can manually operate the 4wd mechanism in the tranny. this is what subieecch refers to by "getting rid of all that crap and install a lever"""" Are there any kits or plans etc. to do this, or do I have to fab something up? How hard a job is it? yes, I'd guess that you would have to fab something up yourself to do this. I'd imagine once you got the (possibly bad) diaphram unscrewed, you'd see what you need to move to engage 4WD. It may just be easier to get a new diaphram from a junkyard and replace it. Link to comment Share on other sites More sharing options...
