Help Help Fast Fast
PCV valve - back of the intake manifold near the middle. 17mm attached to a hose. Follow the hose comming from the little white foam filter inside the air filter houseing and you'll find it. Replace the foam filter too.
Carb inlet? C'mon are you serious? Take off the air filter top and it's the BIG hole in the middle. :rolleyes:
