barrow72000 Posted April 4, 2006 Share Posted April 4, 2006 Where is the pcv valve and the carburetor inlet on a ea 82 1987 model Link to comment Share on other sites More sharing options...
barrow72000 Posted April 4, 2006 Author Share Posted April 4, 2006 Where is the pcv valve and the carburetor inlet on a ea 82 1987 model Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 4, 2006 Share Posted April 4, 2006 PCV valve - back of the intake manifold near the middle. 17mm attached to a hose. Follow the hose comming from the little white foam filter inside the air filter houseing and you'll find it. Replace the foam filter too. Carb inlet? C'mon are you serious? Take off the air filter top and it's the BIG hole in the middle. GD Link to comment Share on other sites More sharing options...
northguy Posted April 4, 2006 Share Posted April 4, 2006 Find the "mini pad" in the air filter and follow the tube to the pcv valve. Link to comment Share on other sites More sharing options...
