Ea81 / Ea82
Would the 81/82 bolt right up? or are the mods needed? I thougt about transplanting my Lt1 into the gen 1, but it's too big. :rolleyes: Showing my ignorance here, what's an EJ25? Thanks.
a better question would be "would an EJ25 fit?" :)
and yes an EA81/2 should fit just fine
Ea82 is wider than a EA81. Ive heard of people having to modify their frame rails to fit a EA82 into their EA81 vehicle. I think the engine bay of a Gen1 is even smaller than that of a Gen2, so Im not sure a EA82 will fit right.
The EA81 should work. I believe you'll need the engine crossmember from a 1981 Brat (Gen1 with 1800) for it to bolt right up.
-Brian
EJ25 is what they use in a majority of the newer subarus. Its what the STi uses.
