Dangerdave Posted April 6, 2006 Share Posted April 6, 2006 Hey, Just looking for an answer to this question. I've searched and found one person warning that it may sit high. Is this true? If so could I swap springs to return it to regular ride height? Thanks for any advice Dave Link to comment Share on other sites More sharing options...
ballitch Posted April 7, 2006 Share Posted April 7, 2006 well if you put impreza springs/struts into a legacy and it makes it sit lower, then legacy springs/struts should make it sit higher. you could cut about an inch off of the legacy springs, and put them back on the legacy struts. but you know you can get the wrx springs/struts for the 93 impreza right....and brakes, wheels, steering rack, sway bars....etc.. ~Josh~ Link to comment Share on other sites More sharing options...
970subaru Posted April 7, 2006 Share Posted April 7, 2006 I have impreza struts on my car. its the same. you can screw with the ride height by mismatching springs and struts, but if you are dealing with strut assemblies from a legacy they should be the same height. its the same chassis. Link to comment Share on other sites More sharing options...
Dangerdave Posted April 7, 2006 Author Share Posted April 7, 2006 No I thought the Legacy and Impreza chassis were different. The Impreza was developed as an "all new vehicle" for 1993. But if you say they work well enough... You dont find they sit any higher? The reason I'm asking about the useability of these struts is because I already have them. Thanks for the replies, Dave Link to comment Share on other sites More sharing options...
Dr. RX Posted April 7, 2006 Share Posted April 7, 2006 No I thought the Legacy and Impreza chassis were different. The Impreza was developed as an "all new vehicle" for 1993. But if you say they work well enough... You dont find they sit any higher? The reason I'm asking about the useability of these struts is because I already have them.Thanks for the replies, Dave Well, I guess you need to understand what was meant by "all new", aside from the engine, tranny, and most of the suspension, it is a new car, they ever route the wiring differently on the Impreza. Link to comment Share on other sites More sharing options...
